Question about Canon BubleJet i965 InkJet Printer
Canon i965 flashing amber light
Amber light flashes 5x alternatively on my canon i965 printer, will not reset
    Scholar:
  • 94 Answers
Your printer experienced a PrinterPlease try the following to resolved that issue:
1. Resetting the Printer
By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur.
Follow these steps to reset the printer:
Turn the printer off with the Power button (if available).
Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
Turn the printer back on.
2. Reseat Print head
*Confirm that the printer is powered on.
*Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
*After confirming that the print head holder has moved to the center, open the inner cover.
*Remove all ink tanks.
*Raise the print head lock lever and remove the print head.
*Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
*Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
*Close the inner cover and top cover.
Note: Check that each ink tank is installed in the correct position.
If those steps above are exhausted and issue still present printer may require service.
Posted on Jun 11, 2008
Hi nnub1,
You might try unplugging the printer from electrical source and try unplugging your data cable from the computer. Shut down your computer and disconnect the data cable. Start your computer and then reconnect the data cable. This is assuming you have a usb data connector.
What you want to do is to try to get the printer back to its default settings. The amber light flashing is trying to tell you something. You should also unload any pending documents to try to get the printer back to its default state, but disconnecting data cables and or power connection is going to be required.
Respectfully,
Terry
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Canon Pixma iP1800: amber, green, amber, greeeeen flashing lights
what error message coming from your computer...i think something stuck inside your printer
Feb 24, 2010 | Canon PIXMA iP1800 InkJet Printer
Print head failure signal
Error 5 is an ink cartridge error. Cleaning the print head and electrical contacts on the cartridge does not fix this error. You need to get a new cartridge to fix the problem.
Feb 09, 2010 | Canon BubleJet i965 InkJet Printer
Do I need a new print head?
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i455 printer displays canon service error 5C00
paper mechanism is vey suspect - time for a new one
Jul 18, 2009 | Canon BubleJet i965 InkJet Printer
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
Error message 5200 on Canon printer i965
Sent the printer for repair to the local Canon Service Centre.
Apr 14, 2009 | Canon Office Equipment & Supplies
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Canon BubleJet i965 InkJet Printer Logo
1,021 people viewed this question
old marine
old marine
