Question about Electric Door Light Switch
Renault megane 1998
PASSENGERS SIDE ELECTRIC MOTOR WINDOW NOT WORKING
  • 21 Answers
Common megane fault im afraid the water gets down by rubber and lands directly onto motor. great french design. new one im afraid and try to place something over motor bit of plastic to let water drip away. parts handy got on line. look up megane window motor and see results on google. about 65 sterling. regards mike autosolutions.ie
Posted on Mar 26, 2009
Both the passenger side electric windows have stopped working at the same time
It's possible your switch to all window's on the driver's side has failed and needs replaced. It would be a fluke that both window switches quit at the same time but it is possible. I've always found that these switches very rarely completely fail. What usually happens is they become dirty and are not making good electrical connections. Remove your driver's side switch and spray it with a good electrical cleaner and see what happens.
Sep 10, 2014 | 2003 Renault Megane
T reg renault megane passenger window dont work from driver side switch but does work on passenger switch
that would indicate a problem with the driver side switch remove and check that its connected ok and not loose if looks ok check for power to and from switch
Apr 08, 2014 | Cars & Trucks
Near side rear light wont work on a renault megane scenic
take it to your local garage they should check your fuses for free
Feb 01, 2013 | 2006 Renault Megane 1.5
Renault Megane 1.4 16v Dynamique 2003 Problems
where do you plug a diagnostic machine to in my
renault megane1.4 dynamique 16 valve
Aug 27, 2012 | 2003 Renault Megane
1997 Renault Megane Scenic 1.6l. Electric windows the passenger side switch would only operate the window upwards not down. Now the control located on the drivers side has the same problem. I can hear a...
there is a relay which is part of a mutifunction module rh lower a post area check the wiring/connectors for water ingress and also broken wiring around door hinge area
Jun 20, 2017 | Renault Sportwagon Cars & Trucks
Passenger side window motor
Negative. Different Motor all together.
Jun 11, 2009 | Renault Sport Cars & Trucks
Knocking noise Renault Megane 1998
this is a white box on the other side of the passangers dash board. lift up the bonnet and disconnect it. that will stop the noise but now your heaters will only get warm instead of hot. its some sort of flap to do with the heater matrix. realy anoying
Apr 28, 2009 | 2000 Renault 181
Renault Megane sport 1.6 2000
gearbox needs changed or clutch release bearing
Oct 03, 2008 | 2000 Renault 181
Renault Megane
this might sound silly but check you do not have the child lock on.
please leave feedback
Jun 29, 2008 | 1986 Renault Sport
Electric Door Light Switch Logo
538 people viewed this question
Top Electrical Supplies Experts
ashburton
Steve
epangan29
Are you an Electrical Supply Expert? Answer questions, earn points and help others
