Question about Samsung HP-S4253 Television
Blue Noise/Pixels Bottom Left Corner of my Samsung Plasma
There is a lot of blue noise/pixel spots that move around the bottom left hand corner of my Samsung HP-S4253 screen & I saw in another post you said lowering voltage helps these problems, but how exactly do I do it? Any help would be very much appreciated!!! Thanks!!
You would need to have a technician remove the back of the TV and make the adjustment. There are 2 small adjusters that they change to adjust the voltage.
Posted on Jun 24, 2008
A lot of dead pixels red and blue appeared in upper left corner. Is there any solution to this?
Not much that can be done about this damage to the monitor, probably in shipping.
Jul 04, 2010 | Samsung SM943N 19" LCD Monitor
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue Noise, left side of TV
I have the same problem -- had a Best Buy technician out 4 times so far, replaced 2 parts, adjusted the voltage, etc., but still have the same problem -- looks like there may be no solution other than replacing the TV, which is an expensive proposition considering that mine is about 18 months old.
Jun 12, 2008 | Samsung HP-S4253 Television
Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Jan 01, 2008 | Televison & Video
Red pixels "noise" that shift around on left side of by plama,
This is a diffusion problem and can be solved by lowering some voltages in the television. Sometimes it is the powersupply though. But you can try adjusting V-SUS and V-SET and V-SCAN for best picture. But you have to switch between light and dark sources to make sure you got it all the way. One quick pattern you can put up is the burn in protection screen. The Wipe one from black to white while adjusting the set. Let me know how this pans out for you. Good luck. Have fun. Jay
Dec 27, 2007 | Samsung HP-R5072 50 in. Plasma HDTV
Screen problem blue area in the corner
remove any big speakers that are close to the tv
Dec 17, 2007 | Televison & Video
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Televison & Video Logo
395 people viewed this question
Henry  Thomas
Henry Thomas
