Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
NO Signal on TV but Foxtel works
Message.."NO Signal" for all TV chanels but Foxtel works fine
Model actually Toshiba 37WLT66A
    Brigadier General:
  • 6,966 Answers
I am assuming that you have confirmed that your Foxtel works in another TV but not with the Toshiba 37WLT66A and that you are using a single feed from the cable provider and split into two (or more). Additionally, this is a standard cable connection.
If the unit is new, then perhaps it is a matter of programming the Channels using Cable not Std or Air in the menu. If the Toshiba has been used before in the same setup, then possibilities are:
1. cable/connector leading to the Toshiba;
2. splitter or distribution amplifier (if present);
3. worst case scenario, tuner block of the Toshiba.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
  • 868 Answers
Sounds like your cable box is programmed and not your channels .Why not have your cable carrier re program ???
    Master:
  • 638 Answers
It can be a temporary problem with some networking.just let me know how long u r facing this problem.
  • hemant somaiya
    hemant somaiya Jun 10, 2008
    if u dont hve a manual thats a link to manual for additional reference:
    http://www.toshibaav.com.au/manual/32_37...
    for further assistance feel free to ask. if my solution helps u anyway,rate this solution as "fixya".thanks.
  • hemant somaiya
    hemant somaiya Jun 15, 2008
    do u require any more help or is ur problem fixed.let me know.
    Genius:
  • 1,142 Answers
Try doing a hard reset to the device
  • Maanita Chadha
    Maanita Chadha Jun 10, 2008
    Reset the tv menu and start channel scan and that will resolved the issue
I bought a LG tv model# 22LG3DCH and I cant program the chanels it says no signal but other tv pics up just fine.How do I fix it?
[PDF]Commercial Mode Setup Guide - LG.com
www.lg.com/.../32ld345h-commercial-mode-setup-guide....
LG ElectronicsThe model and serial numbers of this TV are located on the ... However, there is noguarantee that interference will not occur in a particular ... the TV by the hanging power and signal cables on the back ..... program guide (EPG) data provides additionalchannel and program ..... If set to 1, cannot tune from current channel.
How to resolve the No Signal or No Channels in Master List ...
? 2:07
https://www.youtube.com/watch?v=Tk7EUAEncsQ
Oct 6, 2014 - Uploaded by VIZIO
How to resolve the No Signal or No Channels in Master List message. ... Show more ... Why Does My TV Say ...Missing: 22lg3dch
LG TV "No program information" - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/55640-4-program-information
May 24, 2012 - 7 posts - ‎5 authors
I bought a 35" LG TV a few months ago. ... TV on and it was (and still is) displaying "No program information" instead of ... All other information about the current channel is displayed OK. ... Diamondhead said: ... Can't find your answer ? ... a LG Sound BarModel LAS350B to a Toshiba TV Model 32C110U1?
Jan 05, 2016 | LG Televison & Video
UNLOCK TV TOSHIBA
Call Toshiba @ 1800_618_4444 with the same information you provided here, or use .http://www.toshiba.com/tai/americas/index.jsp
Aug 07, 2014 | Toshiba REGZA Televison & Video
HOW TO GET UNLOCK CODE ?UNLOCK TV TOSHIBA
"If you cannot remember your PIN code
While the PIN code entering screen is displayed, press [RECALL] four times within five seconds. The PIN code will be cleared and you can enter a new PIN code."
Or you can trye this:
Step3Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
My toshiba lcd is 5 years old and i been using it in uk now iwant to watch australian free chanels model no is 42x3030d
You have to select analog tuner to scan for the antenna signals.
You can select this in the menu.
Regards GJ
Jun 22, 2014 | Toshiba Televison & Video
We can get analogue tv and foxtel chanels but we have lost all digital tv chanels. We have run a full scan but nothing happens
unplug the power cord plug from the tv then unplug the antenna cable look inside the antenna metal peace make sure the wires are not touching to each other first connect back the antenna plug then the power cord if its an interior antenna your problem is the antenna
Oct 17, 2010 | Sony BRAVIA KDL52XBR2 Television
I have a Toshiba 40RV525U LCD TV. Wondering how to
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
Weak or no signal message
  1. Since my problem (Samsung/Comcast) began with a channel selection button pushed on the TV remote when it should have been pushed on the cable remote, I figured the problem lay with the TV.  Although I was getting the "weak or no signal" msg., the actual signal strength bar graphic showed it to be strong. Disconnecting did no good. I surmised that the TV was simply not recognizing the box.
  2. I looked at the manual for my Samsung 750 model.
  3. Page 20 discussed "Selecting the source". I accessed the TV menu and selected "Input", then chose the "HD..." item from the highlighted list. Voila! My tv works again.
Jun 08, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
I have a toshiba rear projection tv model number 51wh36p the picture has started distorting as if the tv wasnt tuned in properly but all the menues are fine just the picture and it also the same on the av...
The first thing to do is to isolate whether you have a tuner problem or the TV itself.
How does the picture look when you play a DVD? Any problems?
What is the source for your TV signal (built in tuner, cable box, satellite, etc.)?
Feb 17, 2008 | Televison & Video
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
179 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
