Question about Car Audio & Video
I have a peugeot 207cc and I had a peugeot cd changer(it is actually a Blaupunkt)installed. My problem is that the cd changer always starts from cd 1 track 1 on initial startup and does not remember which cd/track it was playing when the ignition was last switched off.
  • 1 more comment
  • cdchanger Jun 10, 2008
    I tend to agree that the unit does not have a 'always on' supply. How would I know which Pin I should power with the battery power on the cd changer?
    My peugeot 207cc has got a standard Peugeot cd/radio fitted which is made by Siemens (according to the label fitted on the unit) The CD changer is a BLAUPUNKT IDC-A04 and is fitted to the cd/radio by a special harness which fits in the main plug of the cd/radio. Maybe this can help you be more specific. Thanks for your help.
    Some further information - I have just checked the voltages on the harness leading to the cd changer - There is 12 V on Pin 1 (and it is a yellow wire) with the car and stereo switched OFF.
  • 435 Answers
Click on this link and replace the part:
Resolve Memory Loss
Thanks
Posted on Aug 30, 2008
  • Narmada Anand
    Narmada Anand Aug 30, 2008
    The problem may be because the contsant 12V and the memory
    12v need to be changed over, the wires should be the red and yellow, if
    i remember rightly.
    if you look at the plug face on, the yellow wire is top second on the right, and the red is second line down far right.
    Please rate the solution.
    Thanks
    Brigadier General:
  • 6,966 Answers
I would venture that the main B+ wire of the Blaupunkt CD Changer is not connected to an always on B+12 such as the positive terminal of the battery. This wire is responsible for memory/location/track last play retention. The other B+ of the CD Changer is the remote trigger on which is fed by and from the head unit. This in effect makes the unit operate with two (2) B+,an always on and a triggered on.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Jun 10, 2008
    Of course in some instances, it may be the head unit that is missing the always on B+. This could be confirmed if the radio (FM/AM) radio presets revert to default on powerup of the headunit.
  • Louie  Role
    Hi again,
    You would need a DVM (voltmeter) and with the power on to the unit, test which of the wires carry +12, chances are it would only be two. If the system follow ISO standard, then yellow would be for the always on B+ while red would be the trigger on B+. In some installations, the red could be connected to the blue or blue/white of the head unit.
    If for some reason a different wiring color scheme is used, I guess given a choice of two wires (both of which technically receives 12V), you can try a little experimentation with no possibility of any untoward incident. If the first guess/choice does not work, then it would be the other. Sorry for the guess work but not knowing the exact model of the CD Changer kinda limit information.
    Again, good luck.
  • Louie  Role
    ohhh, your post indicates that there is an always on B+12 on the yellow wire which should make the unit retain memory of last setting. Since this is contrary to what is happening, then it can be safely assumed that the CD Changer has a slight electronic fault which prevents memory retention.
    This fault could be a simple case of internal loose connection or cold solder or even a corroded/looses terminal connector outside. Other than confirm that the harness is snugly fitted to the CD changer through its connector, am afraid that further diagnosis would require opening the unit up.
Hi Can anyone be kind enough and give me a code for blaupunkt 2040 from my peugeot 206? 14 digit code is BP8146x2387842 and the 10 code is 7648146392. Many thanks
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Peugeot service centre and get them to enter this code for you.
Dec 04, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt cd5 changer does not have an eject button how do i retrieve my cd's?
If it has a magazine, you'll have to remove it. Some magazines push in to latch and you can push to unlatch and pop out
Sep 18, 2012 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
My cd changer came with lead that doesnt work where can i get one from?it is a blaupunkt idco4
Simple answer: Ebay!
Search for "changer cable", it will come up as either peugeot or citreon changer cable
Mar 10, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 BP905038637756 7607769050, code please?
PEUGEOT Blaupunkt
There may be 2 different codes depending on how old the car /radio  is.
Try 3963
and if your radio will not accept any digits higher than 6 ( ie 6666 is the highest  )
then try 2211
Sep 04, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC A09
hi whats your email?
will email you.
mark
Jul 19, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
5 cd incar stereo
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Dec 13, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Mar 11, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Car Audio & Video Logo
212 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
