my phone is the same model and did this but when i charged it, after about an hour it would come up with 'charging error stop ' and when i unplugged it, it hadn't even charged at all. and then the other day it just wouldnt charge, i plugged it in, it said it was charging but it wasnt. in the end, it worked by keeping the phone switched off and charging it while i was turned off. so try that, if not then i really dont know sorry
I had this same phone and the same thing happened to me. I kept shutting it off and on - also taking the battery in and out. I eventually got the screen to light up but it would only last a few seconds. Sorry to say but you will most likely need a new phone. I had to replace mine.
More than likely you will need to replace the LCD screen. The backlight may have burned out making it blank or it the LCD connector may have come loose.
A new LCD screen runs about 15 dollars shipped from ebay.
The W580i LCD is easy, easy to replace. Probably one of the easiest I have ever done.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Ok, my phone had the same problem. I took the face plate off and the screen out and there's actually a little connector that connects to a board behind the screen(can come unplugged for replacement). I fiddled around a little with it and it worked fine. about a week or 2 later it happened again. I tried fixing it again and it would just flash white>black>lines>white, repeat. I know my phone's taken a bit of abuse, dropped down a road, soaked in rain, but it always worked after. These phone screens aren't meant to take abuse. Problem; the phone screen died. Solution; get a new screen.
You can take it apart and try to reseat the connector. If that fails to fix it then you will need to replace the LCD screen. A new LCD screen runs about 15 dollars shipped from and it is a pretty easy replacement.
