Question about Toshiba SD-V55HT System
Dvd and progressive scan
Accidently selected progress scan and can not return to dvd menu in regular mode.
THIS IS COVERED IN THE MANUAL. I DID THE SAME THING A YEAR AGO AND RESET IT BY FOLLOWING THE INSTRUCTIONS IN THE MANUAL. DON'T HAVE IT HANDY AT THE MOMENT BUT YOU CAN FINDI IT ONLINE. KEEP IN MIND THAT THE PROGRESSIVE MODE ONLY WORKS WHEN YOU HAVE IT CONNECTED VIA PROGRESSIVE SCAN.
Posted on Jul 13, 2008
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
How to set the "Progressive Scan" to "off"
I did the same thing. Hit progressive scan and now I have sound but no picture. I can't get to the menu to turn progressive scan off! Help!
Feb 23, 2009 | Sony DAV-SB100 System
I accidently hit the progressive scan button and now I can't get a picture when I try to watch a dvd.
just talked to LG Customer support and got them to send me a manual.
to turn off the progressive scan insert a disk and once it starts playing press stop, then press stop again and hold for 5 seconds this will turn off the progressive scan mode.
Dec 09, 2008 | Zenith DVT412 System
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
DVD/VCR stuck in Progressive scan mode
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS. Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk. Try it & Good Luck!!!!!!!!
Nov 02, 2006 | Zenith XBV442 DVD Player/VCR
I cant get back to s-video mode.....:(
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability
Sep 23, 2006 | iLO DVDR05 DVD Recorder
Turn off progressive scan mode
If you set progressive scant On by accident,you must reset the unit. Remove any disc from the unit and close the disc tray. See that "disc" is displayed on the display window. Now press STOP and hold it for more than 5 seconds before releasing it. The video output will be restored to the standard setting and picture will once again be visible on a conventional analog TV or monitor.
Sep 05, 2006 | Zenith XBV443 DVD Player/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Toshiba SD-V55HT System Logo
195 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
