Question about Sony Ericsson P1i
I want to know browser
I was already connected to a wi-fi but i cannot find the browser. where i can it? i want to search yahoo.com or google etc. do i need to go out rom the wi-fi and go to the other application?
I can't connect the GPRS on my Sony Ericsson P1i. I have put the IP address, Service Provider name as they send to me for activated GPRS at my mobile. So, Please suggest the best way that i can connect the GPRS at my mobile.
thank you,
yogesh nepal
Posted on Jun 13, 2008
Connect my amazon tap to the internet
To connect Amazon Tap to a Wi-Fi hotspot:
  1. Go to the settings menu on your mobile device and search for a Wi-Fi hotspot option. ...
  2. In the Alexa app, open the left navigation panel and then select Settings.
  3. Select your Amazon Tap, and then select Update Wi-Fi.
More items...
Amazon.com Help: Connect Amazon Tap to a Wi-Fi Hotspot
https://www.amazon.com/gp/help/customer/display.html?nodeId=202021980 https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=how+to+Connect+my+amazon+tap+to+the+internet
Dec 23, 2016 | Amazon Tablets & eReaders
Can not connect to Wi-Fi
Do you mean for the Amazon Kindle store? Provided your wi-fi signal is good, which you can check by trying it with a smartphone etc, the Paperwhite should connect itself to Amazon automatically when in range. If not, try these things
- verify the Pw (Paperwhite) is registered properly (ie Amazon knows it)
http://www.amazon.com/gp/help/customer/display.html?nodeId=201235720
- check your network is listed already on the Pw
http://www.amazon.com/gp/help/customer/display.html/ref=help_search_1-1?ie=UTF8&nodeId=201241790&qid=1457135457&sr=1-1
- generally speaking
http://www.amazon.com/gp/help/customer/display.html?nodeId=201852540
If you are talking about wi-fi and using the Pw internet brower, forget that, it is not worth the effort, the Pw browser is such a non-intuitive dog of a thing.
Mar 04, 2016 | Amazon Kindle Paperwhite
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
I bought a used apple powerbook G4,my wifi does not work without a password but I don't know that password, how do I find password
Lack of information , What is the model number of the wi-fi router. Once you know this google search for default ip address (with the router model number) then google search default password (with router model) then open a browser with p.c or laptop directly connected to the router via an ethernet patch cable. Type in ip address in browser. then log into router. And go to security and look what the encryption key is and make a note of it, if you have a working device already on the wi fi you may be able to log into the router. typical default router addresses are 192.168.0.1 ot 10.0.0.1 your may be different.
Dec 23, 2013 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Proxy address for samsung quadpad GT-S5233
1. Go to Menu.
2. Select Browser.
3. It will prompt you to create a new connection. Select Create.
4. In the next section leave Set Name as it is (or you can change it if you like)
5. In Bearer type drop down box Select Wifi.
6. In the next prompt select Search Wi-Fi Manually.
Wi-Fi will turn on and search for a Wi-Fi network in the region automatically.
7. Select the Wi-Fi network you want and It will save its name.
8. Leave the rest of the things as it is, no need to change any more settings.
9. Just select Save Button, It will directly take you to Browser profile page with the newly created profile listed(Default Name: Connection 01). Select the Radio Button in front of it.
10. Now come out to the main menu.
11. Now go to the Wi-Fi Tab, as it is already on it will show you the Wi-Fi networks in the region, if its not, turn it on and search again.
12. Select the Wi-Fi network you want to use and, select Connect.
13. Depending on the signal strength it will try connecting.
14. Once connected it will give you a message saying connected, you might need to attempt it a couple of times.
15. Once connected exit out and go to any shortcut on your phone or select Enter URL and type in the name of the Site you want to browse to.
16. There you go, you can start browsing to all your favorite Sites now.
Jan 05, 2012 | Samsung Star GT-S5233 Cell Phone
I cannot connect to our office wi-fi connections. It says authentication failed. how can i able to connect. pls help me.
Hi,Please try these steps:-
Wireless router side
  • 1. Set wireless mode to B-G Mixed
  • 2. Standard Channel = 8
  • 3. Encryption - TKIP
Phone side
  • 1. Delete the configured wireless connection/s if you already have one.
  • 2. Enable wi-fi but do not perform search at the moment
  • 3. Now open the browser and select settings then browser profiles press search for wi-fi.
  • 4. Select the connection that you want to connect to then type the details and match the settings on the router.
  • 5. Auth type = WPA, encryption = TKIP, network key = router pre-shared key, protocol = HTTP, Home URL = address of modem (you can change it later if everything is already working), leave proxy blank, linger = default, adhoc = off, no need to do advance settings.
  • 6. Save the settings and do not connect yet.
  • 7. Exit the browser and go to Wi-Fi and select the connection that you have just configured and select details.
  • 8. Check all the settings if ok. if the channel is different with the router, adjust it on the router to match the one used by the phone. IP address = not connected (it will automatically connect once you browse the internet).
  • 9. Now, try to browse the internet but you must set first the connection you've just configured as default connection.
hope rhis will be helpfull to you. Please rates me. goodluck.............
Feb 03, 2011 | Samsung Star GT-S5233 Cell Phone
How to connect wifi..
  • 1. Set wireless mode to B-G-N Mixed
Phone side
That's it. I hope that this helps. This applies only to personal wireless network.
Happy browsing!!!!
TOM
Jan 03, 2011 | Samsung Star GT-S5233 Cell Phone
How to connect Wi-Fi on SAMSUNG 5560
Please try these instructions:
Phone side
Oct 31, 2010 | Computers & Internet
WIFI
connect to wifi using my blackberry curve 8520 1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
Mar 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
Sony Ericsson P1i Logo
118 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
