Question about White Sewing 2037 Mechanical Sewing Machine
Bottom thread i borrowed my mom's white 2037 sewing machine. i have the top thread ready to go and the bobbin is in place but i can't figure out how to get the thread to come out of the right place, or even where to have it come out of. can anyone help me?!
  • 497 Answers
please check out this website
All the best
Happy to help
have a nice day!
Posted on Jun 10, 2008
White 2037 twin needle keeps breaking thread
Thread breakage occurs commonly with mis-threading. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Also, since you are using 2 threads, thread one completely and then thread the other so the threads do not get twisted in the thread path. If your machine has duel tension disks, thread each tension disk separately with a single thread. Setting the thread spools to turn opposite directions may help.
Also, make sure the needle eye is the right size for the thread. Thick or thin thread could break easily in the wrong needle.
Also, use only good quality thread--no bargain bin or old threads!
twin needle thread breakage Google Search
Nov 25, 2017 | White Sewing 2037 Mechanical Sewing...
White 2037 Bobbin thread not spinning and noticed the needle hitting bottom of bobbin casing
it's sounds like the machine could be out of time & the machine needs to be checked at a sewing machine shop, to find out for sure.
May 10, 2012 | White Sewing Sewing Machines
Top thread is fine bottom thread all jumbled
I've had the same problem - jumbled threads on the underneath side of fabric. My solution was this: I had recently purchased new bobbins and they turned out to be the wrong size. I went back to the ones that came with the machine and the problem disappeared. So, have you recently purchased new bobbins? They might not be the correct ones. Funny, in all of the posted possible solutions below, not one mentioned this possibility. turns out my new ones were not as tall and were slightly concave instead of taller and flat. Check your machine manual for the correct bobbin part number.
Nov 23, 2011 | White Sewing 2037 Mechanical Sewing...
Keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
I need instructions on how to thread and which
You can get an instruction manual for your machine at for about $10.00.
Happy sewing!
Jan 28, 2010 | White Sewing 2037 Mechanical Sewing...
The bottom stitching is loose it is just like the bobbin tension was lost in the middle of sewing
If the thread is lopy on the undrsde:
tighten the needle tension
check the needle for bent or burrs, put thread through the needle and pull back and forth by hand if the thread shreds, burr in needle, change needle
make sure thread is the same on top and in the bobbin are the same weight
Aug 28, 2009 | White Sewing 2037 Mechanical Sewing...
Bobbin jumps out of place while I'm sewing and jumbles the thread. I took it to a repairman, it worked for about 3 weeks. Now, same old problem.
I had a similar problem but found it only happened when I used plastic bobbins. I've been using metal bobbins and haven't had the problem again. Hope this helps.
Jan 28, 2009 | White Sewing 2037 Mechanical Sewing...
Rebecca, I don't know if you ever received a solution, but after my experience with my White 2038, I would advise you to do exactly what you said. "Throw it out". I've struggled for a week with a new machine, found parts missing after opening the box and generally feel ripped off. I am throwing mine out! I purchased a Singer yesterday and it is sewing beautifully with no problems.
Good luck.
Jul 03, 2008 | White Sewing 2037 Mechanical Sewing...
Bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Jan 14, 2007 | White Sewing 2037 Mechanical Sewing...
White Sewing 2037 Mechanical Sewing Machine Logo
139 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
