Question about Compaq Computers & Internet
Water into the computer - Compaq Computers & Internet
  • 191 Answers
Use a air blower and try blowing air , you can use a hair dryer
first of all be sure that all the water is dried up
then try powering on the system then let us know what happens.
Posted on Jun 10, 2008
Keeps coming up c4 56
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Usually tankless computer water heaters are not repairable by homeowner... or anyone else if unit is older than 6 years.
Smae applies to laptop computers, telephones, garage door openers and other computer-chip operated devices.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Mar 17, 2014 | Rheem Tankless Hot Water Heater...
Computer box is wet
sure it dont., how can it.?
water conducts electric current. (unless 100% pure)
wet electronics, are a doom thing.... hopeless.
new cars have water proof main boards and 100% water
proof connectors, (not pressure washer safe)
but most dont allow water.
but you never said which computer, my 2008 has 15 computers in the car all talking over a CAN-BUS network.
why not cure the water incursion first.
the dry out the ECU (or what ever computer means)
with and oven set to 125f. (desert temps)
Feb 20, 2014 | 2007 Toyota Quantum 2.7
Green active lights on but not red standby and no hot water
If tankless computer is less than 5 years old, then call Rheem for local technician qualified to work on this type of computer that heats water.
If tankless is older than 5 years, then replace with tank-type electric water heater for $285 from Lowes.
Avoid Rheem, Richmond, Palmoa, GE water heating products since this company does not post service manuals.
Choose AO Smith, American, State, craftmaster, Whirlpool etc.
Gene
h
Oct 01, 2013 | Rheem RTE-9 Electric Tankless Water Heater...
I have a paloma ph6dp water heater that hasn't
You have an old tankless computer and it won't work?
What would you do if you had old laptop computer that didn't work?
Copy following links for possible resources including required yearly maintenance so tankless computers can last 4-6 years before needing replacement:
Gene
h
Sep 07, 2013 | Water Heaters
My Takagi TK3 isn't heating as it should. Had a tech out and he adjusted the dip switches to 140 degrees, which worked for a while but now it barely heats to 100 degrees. Gas flow rate appears to be...
Is tankless computer older than 5 years? Imagine how well a 5-year old laptop computer works.
Setting temperature to 140 degrees might be the basic problem:
Read following resource:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
I doubt this Takagi computer unit was maintained as shown in product manual, and that heat exchanger was not delimed each year as shown in product manual. So the heat exchanger is probably heavily coated with un-removeable scale... since yearly deliming will not fully remove scale on tankless units, the tankless computer is designed to sprial downward in efficiency despite glossy brochures that promise endless and effortless hot water for 20 years ... as if any computer will last 20 years:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
Since you are not getting error code, the problem might be crossover, or some other plumbing problem:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#no-error
http://waterheatertimer.org/Crossover.html
I always recommend replacing tankless computer with tank-type water heater for $385 for same-day do-it-yourself solution and to save the endless expenses that arise with computer-driven water heaters.
Gene
h
Aug 30, 2013 | Takagi T K3 OS P OnDemand WaterHeat
My Jacuzzi J-N180F tankless water heater will not even light.
Access your product manual.
I cannot find a product manual.
Some major company, like Rheem, makes this computer that heats water.
Call service technician to repair the unit.
Copy following link for overview of type of problems found with tankless computers.
For example tankless computers require continual maintenance on yearly and monthly basis to prolong expected life of product.
If tankless computer is older than 5 years, then assume it is like your 5-year old laptop computer.
Save problems, and repair the unit yourself, same day, by installing tank-type water heater:
Gene
h
Aug 27, 2013 | Jacuzzi 7.5 GPM 180000 BTU Internal Gas...
There is power to the system but when you turn water on elements do not come one and heat water. all phases have 238 volts to them. why will system not turn on and heat water
Do you have 3-phase water heater? Is this balanced or unbalanced 3-phase unit. Add comment and describe product in detail, including brand since i have some service resources for both types.
Or do you have ordinary residential split-phase 240Volt Bosch tankless computer that heats water, and has 2 or 3 separate elements, and a separate circuit breaker supplying power to each element? And testing across both hot leads coming from each breaker yields 238Volt?
Copy following link for Bosch tankless manuals, with brief troubleshoot section that does not provide detailed service procedures for repairing tankless computer:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html#manual
If this is new water heater, then call installer. If you installed yourself, then remove tankless and return to seller for refund.
Tankless computers require certain amount of water flow to activate computer sensors. Turn on Hot tap and listen to pipe to hear if water if flowing through hot pipe. Check for crossover:
Clean water filter usually located just above where cold water connects to unit.
Delime tankless ... and use water softener. Tankless cannot be exposed to more than 11 grains hardness in water, or parts will fail within 2-3 years. Simply deliming tankless heat exchanger each year will not maintain full efficiency... although for typical family of 4, tankless comper water heater costs $100 more to operate than tank-type heater according to manufacturer's promo literature and independent studies.
Call local technician who specializes in fixing tankless computers. For plumbing problems call local plumber. These are two different things.
If tankless computer is older, then cut losses, and buy tank-type electric water heater at Lowes for $285 and make quick changeover and have hot water same day. Sell old tankless on ebay and cheat next guy, or sell at scrapyard for $3 per 100.
Gene
h
Aug 05, 2013 | Bosch PowerStar AE125 AE125 Whole House...
I have the cold water only hooked up. I only USE cold water setting. Why does F 20 keep appearing? Can I not only use the cold water?
F20 means that the water has not reach the level in the time allowed by the computer. when that happens the computer stops the washer. make sure you have good water pressure about 20psi. also make sure you have clean screens at the faucets and water valves.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
2008 Saturn Sky Redline - starting issues. If I
I have the same problem, found that when it rains heavy or I wash the Saturn Sky; water runs down over the computer under the hood on the driverside. There is a drain port just above the computer so water runs down through the drain port onto the computer wiring shorting out this computer, when the wiring dries out the electrical problems are fixed. but the water can do damage to the computer which comtrols the radio and many other electronics inthe Saturn Sky. I know this because this happened to me. after washing my Sky all the electronics went crazy, found the water on my computer wiring. after a couple of times of the wiring shorting out the radio started comming on by its self while the car was shut off causing the battery to die over night. What a crazy place to put a drain port over top of a computer and its wiring. A cover needs to be made and placed over the top of the computer to prevent this from happening again. If you are having a problem getting GM to fix the problem; wash the car using a garden hose and let alot of water run down over the window on the driverside so the water can run down the water port under the hood onto the computer and wiring, this should create the same problem then take it back to the GM dealer and show them the water problem. They can then refuse to correct the problem. Good Luck. O yes one other problem you need to know about, if you don't have mud flaps on the front wheels the paint will chip real bad on the rear lower quater pannels and it will cost you a good dollar to have it repainted.
Feb 11, 2010 | 2008 Saturn Sky
"Limp node" when air con turned on after water got into computer- Help?
when water goes inside the computer it shorted some parts. you need to have your computer tested for possible problem.
Apr 22, 2009 | 1994 BMW 3 Series
Computers & Internet Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
