Question about Whirlpool Heating & Cooling
Whirlpool selector switch reassembly
Dear Sirs:
I need to reassemble a selector switch (airflow and contol switch) for my Whirlpool air conditioner model AC1002XS. It is the switch that selects the functions of " high cool / low cool/ fan only/ off ". Several websites show exploded diagrams for the selector switch for the newer models of AC1002XSO and AC1002XS1 which do not match my selector
switch.
My original intention for disassembly was to rotate the circular plastic
wheel from the "off" position to the ''high cool" position since the knob and stem were accidentally broken off. But, after removing the brass face plate
from the switch, two metal pieces fell out. Each piece is 1 7/8 long by
3/16 wide and the thickness of a business card. In the exact middle of
each piece is a channel or a speedbump , depending on which side you
are observing. I speculate that these might be some kind of spring clips,
but I can''t find any slots in which to insert the ends.
Please advise me on how to reassemble this switch.
Thanks,
Joe Gracki
  • Pileated Joe Jun 27, 2008
    Whirlpool no longer makes a replacement switch for my air conditioner , so "buying a new switch" is not an option.
    I reassembled the switch without the two metal pieces that fell out, and found that the air conditioner works just fine without them. Apparently they were not essential parts.
Buy a new switch!
Posted on Jun 17, 2008
Problem with airflow selector switch
The clicking is caused from a blend door motor not working properly. This motor moves a door in the heater box to control airflow. There may be 2-3 motors in the heating/AC system and one of them is causing the problem and will have to be changed
May 09, 2015 | Cars & Trucks
1997 Ford Taurus front defrost not working
. Air won't blow out of the floor or center vents just defrost ? Do you have manual or automatic climate control ?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob mounted on the A/C-heater function selector switch, which is part of the integrated control panel.
  • The function selector knob has the following positions: OFF, MAX A/C, A/C, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST. The A/C-heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318). Refer to the Vacuum Control Diagram , System Airflow Schematics and Vacuum Control Chart .
  • Two internal, single-pole electrical switches are also controlled by the A/C-heater function selector switch. The combination of these electrical switches controls the electrical supply to the A/C clutch and heater blower motor switch (18578).
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • Vacuum Control Motors The vacuum control motors (18A318):
    • are located on the A/C evaporator housing, A/C recirculation air duct and heater air plenum chamber (18471).
    • direct system airflow to the vehicle interior as determined by the remote climate control module or manual override.
    • The five-passenger seating configuration has an additional vacuum control motor mounted on the heater air plenum chamber to control airflow to the rear seat A/C register (19893).
Jul 09, 2017 | Ford Cars & Trucks
I have a new 5 ton Grand Aire A/C. It seems to take much longer to cycle than my old unit did. Also my plenum is sweating in my attic? Is this normal? Any Suggestions?
sounds like poor airflow if unit is same size as old equipment and duct work is sized correctly you can try raising fan speed if using a pleated type 90 day filter switch to fiberglass non-pleated type filter that restricts less airflow. Also check return air for leaks you could be introducing unfiltered hot air from attic or enterior walls.
Aug 29, 2012 | Whirlpool Heating & Cooling
MY DISTRABUTION DIAL FOR DEF.,VENT, ETC IS IN DEFROST AND WON'T CHANGE. THE DIAL TURNS BUT NOTHING CHANGES. I NEEN SOME ADVICE ON WHAT TO DO TO FIND PROBLEM AND FIX. THANKS GENO
Here is the info. I hope the pictures show up. please rate assistance. thx.
Air distribution within the vehicle is determined by the function selector switch position. Two airflow mode doors are used to direct airflow within the heater core and evaporator core housing. The function selector switch/cable assembly is used to position these airflow mode doors. Refer to Section 412-00 for description and operation of each of the system functions.
Function Selector Cable Assembly
The function selector cable assembly moves the airflow mode doors to the desired position using a 2-sided pull-pull type cable assembly. The function selector controls the cable movement. The end of the cable assembly attaches to the airflow mode door/temperature blend door actuating assembly which transfers the cable movement to the 2 airflow mode doors.
An electrical switch is incorporated into the function selector to notify the A/C switch assembly if DEFROST or FLOOR/DEFROST is selected. When DEFROST or FLOOR/DEFROST is selected, the A/C switch assembly will disable the RECIRC request button and send an A/C request to the powertrain control module (PCM) regardless of the A/C request button indicator ON/OFF status.
SECTION 412-01: Climate Control 2005 Focus Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 02/25/2004
Function Selector Switch adobe.gif Printable View (173 KB) Removal and Installation
  1. Remove the 4 bolts and position aside the lower steering column cover.
  1. Remove the function selector knob.
  1. Remove the center instrument panel finish panel.
    • Disconnect the cigar lighter electrical connector.
  1. Detach the function selector switch.
    1. Disconnect the electrical connector.
    1. Remove the screw and detach the function selector switch.
  1. Detach the function selector cable and remove the function selector switch/cable assembly.
  1. To install, reverse the removal procedure.
Aug 04, 2011 | 2005 Ford Focus
I need to change my neff oven u1744N0GB selector switch. I have a new one, but need to know how to change it out.
pull of control knob first, remove oven from housing and remove top panel undo 2 screws holding selector to fascia withdraw it back into top and change wires there will be quite a few dont get them mixed up! reverse to reassemble.
May 20, 2010 | Neff Ovens
Why does rusty water come from the condensation line on the heating unit?
the box needs cleaned out. the rust is common should be several screws remove clean reassemble
Jan 14, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Not blowing cold air
check the folowing reason of no air flow
-thermostat
- the selector switch
- wiring
-fan motor capacitor
- fan motor
Apr 26, 2009 | Heating & Cooling
Fan does not run
Check out Selector Switch or Fan Motor Capacitor if ok then check Fan motor Winding
Jul 13, 2008 | Whirlpool ACC108PS Air Conditioner
Heating & Cooling Logo
258 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
