Buick Master
- Posted on Oct 28, 2010
Re: Need help changing out the low beam on drivers side...
Removal & Installation
Bulb Replacement
To Remove:
CAUTION
Halogen bulbs contain pressurized gas.
Mishandling a bulb may result in the bulb shattering into flying glass
fragments.
CAUTION
Make sure to wear eye protection when
handling a halogen bulb.
CAUTION
Do not touch the glass of a halogen bulb,
only handle the bulb by the base.
CAUTION
Do not allow a halogen bulb to come into
contact with dirt or moisture.
CAUTION
Make sure to dispose of a used halogen bulb
properly.
CAUTION
Do not allow children to handle halogen
bulbs.
- Turn the lamp switch to the off position.
- Make sure the bulb is cool before changing.
- Remove the headlamp assembly from the headlamp panel.
- Remove the rear access cover from the headlamp assembly.
- Disconnect the headlamp connector.
- Remove the bulb from the headlamp assembly by rotating the bulb and socket
counterclockwise.
To Install:
- Connect the headlamp connector.
- Install the bulb into the headlamp assembly by rotating the bulb and socket
clockwise.
- Install the rear access cover onto the headlamp assembly.
- Install the headlamp assembly into the headlamp panel.
Headlamp Assembly
Chevrolet
To Remove:
Headlamp Assembly (Chevrolet)
- Remove the grille from the front of the vehicle.
- Release the headlamp assembly retaining tabs.
- If equipped, disconnect the headlamp leveling motor connector.
- Remove the park/turn and side marker bulb sockets from the headlamp
assembly.
To Install:
- Place the headlamp assembly into the headlamp panel.
- Install the park/turn and side marker bulb sockets into the headlamp
assembly.
- If equipped, connect the headlamp leveling motor connector.
- Lock the headlamp assembly retaining tabs.
- Install the grille onto the front of the vehicle.
GMC, Oldsmobile, Buick, Isuzu, and Saab
To Remove:
Headlamp Assembly (GMC, Saab, Oldsmobile, and Buick)
- Remove the park/turn bulb socket from the headlamp assembly.
- For GMC, Saab, Oldsmobile, and Isuzu vehicles, remove the side marker bulb
To Install:
- For GMC, Saab, Oldsmobile, and Isuzu vehicles, install the side marker bulb
socket into the headlamp assembly.
- Install the park/turn bulb socket into the headlamp assembly.
need help changing out the - next.gif="/CHEVY_TRAIL_02-07_CH06_Aiming.htm">
