Automatically retarting when I shut down computer
When I log off of my computer and shut it down, it automatically restarts it doesn't shut off. I am running windows xp but I did insert a disk for 2000 premium like 3 times. So I don't know if it is xp professional or just xp it says
  • 4 more comments
  • Jessica17901 Jun 25, 2008
    When I actually hit shut down computer and turn off it says it is shutting down it goes thru the process of shutting down I can hear the hard drive turning off and then I hear the hard drive come back on and restart. Yes I installed windows 2000 premium. I had bought this computer at a yard sale and it had xp on it home edition. I needed word and stuff so I Installed Microsoft 2000 on it. Also I put a modem in the tower my self. The system reconginzes the modem, but also I added 128 of memory which is the same exact memory stick as the computer originally had so now I have 258 of memory, but my registry is like loaded with stuff and not sure what I need to delete because like I said I loaded 2000 like three times and then would go back and hit system restore. I tried last known good config. nothing changes. When I got the computer It shut down fine before I added the modem and the memory. Even when I loaded 2000 and for some dumb reason I hit system restore and erased my 2000 programs that I needed. I guess I was playing around with xp because I have always used microsoft 2000 professional. and the system restore button was new to me. ha ha. Anyway The computer actually says it is shutting down and then shuts down and about 3 seconds later it starts to boot up again. I don't know If I changed something within the system or not. I have no idea what I am doing. I just play around with stuff to learn. Also, when I try to hibernate the system it says it is hibernating and also reboots itself the hard drive or whatever it is that is shutting down starts back up in both instances. So what I am doing for now is just using the standby mode.
  • Anonymous Sep 09, 2008
    when i shut down my pc restart automatically , i am using widows xp
  • Anonymous Jan 12, 2009
    I Have same problem, i am try to Windows Xp is Reinstall.
    But Problem has not solved.
  • gdfgdfgd Apr 27, 2009
    Can anyone come up with an answer to this DAM problem as I have just removed my Modem as I am running broadband and don't need it and now I find that my computer restarts on ever shut down, are computers dum or something as I asked it to shut down not restart sometimes I wonder if computers have a mind of there own?????????
  • mdbcomm May 11, 2010
    disk for 2000 premium? Do you mean you installed Windows 2000 over XP? That won't solve anything. XP is good. What I want to contribute is that my wife's computer has the same restart from standby problem; will never stay in standby. Mine comes out of standby if it senses mouse movement or bump. Disregarding modem: a google search turned up a whole bunch of answers to this problem, relating to Roxio. I have Roxio and so does wife. Other indications I've had on the computer that are more definitely pointing to Roxio makes me suspect that so I will look for a more stable SW to do the same stuff.
  • Dung Nguyen May 11, 2010
    check your bios.
    Disk 2000 ??? huh ?? never heard of it.
    Might be easier if you just reinstall OS
Possible solutions for some users: -
All "crapdows" versions have the same function.
From the Start button, select menu/programs/accessories/system tools/system information, then click on the tools menu and select system configuration utility.
When the program opens, you'll see an advanced button on the bottom right corner. Press it.
Make sure you have disabled fast shutdown (CHECKED). Press OK/OK. If it prompts for restart, don't do it, you dont need to. Press cancel on that screen and then shutdown like you would normally.
Answer I have found I think the answer to that question, although I haven't had the time to test it since it is on a friends computer using xp pro. but you can if you like. go to the bios and check your modem if you are on a phone line and disable the auto start feature...You may find it only restarts when a call comes in...
Answer The bios settings turn the computer on automatically. I actually have mine set to turn on automatically in the morning before I get out of bed so it's already on when I get up.
Watch what you see on your screen as you boot up the computer and do whatever it tells you to do to boot up in bios (typically by hitting the F2 or Del key). Once in bios, go to the power section. In the power setting you should see something pertaining to the modem. If you do NOT want it to power up automatically, choose the Disable option.
If you DO want to power it up automatically, it will also ask for a time (day of month, hour, minute). If you set the day as 1, for example, it will power up on the 1st of the month at the time that is set. If you set the day of the month to zero (0), it will power up every day at that time.
Answer try turning off the hibernation feature that can be found through control panel->display->screensaver tab->power->hibernate and then turn off the hibernation feature
Answer Open your registry: and find the key PowerdownAfterShutdown and set it to "1" to power off the computer at shutdown, or "0" to reboot. Here is the path: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon If you don find it, create it(REG_SZ (String Value)) restart windows
Answer-- All are very good answers. How are you shutting down your computer? Do you go to start shut down and then press ok or do you hit alt + f4? First I would check to see if my pc was set on restart in the shutdown window just before you click ok. If it is change it to say shutdown. Then I would try some of the other answers but they take a good knowledge about computers if you mess up. Hope it helps.
Answer If you leave it plugged into the internet and it has viruses it will switch on automatically.
Posted on Apr 27, 2009
    Sergeant:
  • 458 Answers
2000 Is Windows 2000. Why did you put that disk in? Did you start loading Windows 2000 or XP Pro, XP-Home?
It sounds like your switch is wired to the reset jumper on the motherboard or you are hitting reset.
Tell me what the computer screen has on it before it shuts down please.
I will wait on you answer. Do not rate until we are done.
Posted on Jun 22, 2008
When I click to print, the printer starts, but stop before printing, I must first retart computer, after that it prints automatically.
delete the printer driver and reinstall. your spooler is freezing and it's usually from a corrupted driver install. uninstall the printer and download latest driver from lexmark.
Dec 03, 2013 | Lexmark Office Equipment & Supplies
OmLaptop restarts after being shut down Its a Dell 1545
Hi 1940miker...
Try this solution to your problem
Your computer is set up by default to auto start when a problem occurs.
The computer is configured to automatically restart when Windows stops responding.
To view this setting, follow these steps:
Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
Under System Failure, view the Automatically restart check box.
If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
Please take time to rate me
Sep 04, 2011 | Dell Inspiron 1545 Notebook
Restarts automatically
If you shut down your Windows XP-based computer, your computer may restart instead of shutting down. The computer may also restart unexpectedly while you are using the computer to perform certain tasks. An error message may appear on a blue screen when the computer restarts.
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advancedtab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If theAutomatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
Note: You must be logged on as an administrator or a member of the Administrators group to complete this procedure. If your computer is connected to a network, network policy settings may prevent you from completing this procedure.
  1. Log on to the host computer as either an administrator or the owner.
  2. Click Start, and then click Control Panel.
  3. Under Pick a category, click Performance and Maintenance.
  4. Under the or pick a Control Panel icon section, click System.
  5. Click the Advanced tab, and then click Settings under Startup and Recovery.
  6. Click to select any one of the following check boxes under System Failure:
    • Write an event to the system log
    • Send an administrative alert
    • Automatically restart
I hope this has answered all your questions. If you have any other questions, please contact us at info@custompcrepair.org
Mar 16, 2011 | Microsoft Windows XP Professional
Why the windows was shut down automatically ?
Some programs after installation will auto reboot the computer but this is not common. One option you have to find out why the computer restarted is to go to Even Viewer and look over the Windows log files. You can do this in windows 7 by clicking on Start then typing event viewer and select "view events".
When the event viewer window comes up you can view your computer log files and possibly find out why it was restarted.
Regards,
G33k
Feb 19, 2011 | Microsoft Windows 7 Ultimate for PC
PC is restarting while booting
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly. If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box.
Dec 20, 2010 | Dell Vostro 1510 Laptop
I can't shut down my PC,It restarts again!
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Start up and Recovery.
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: 308427 (http://support.microsoft.com/kb/308427/ ) HOW TO: View and manage event logs in Event Viewer in Windows XP To configure the way that Windows responds when the computer stops unexpectedly, follow these steps.
    At last if nothing works then clear the "Star up"
  7. C:\Documents and Settings\All Users\Start Menu\Programs\Start up
    If you are not satisfied then If you are using XP then repair it.
thanks
Jul 05, 2010 | Computers & Internet
Computer restarts on shutdown
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
My ZD8000 Restarts automatically When I Shut It Down
This sounds like a hardware fault with the motherboard. I would suggest you resseting your BIOS to default settings. Do you know how to do that? Please advise...
Mar 09, 2009 | HP Pavilion zd8000 Notebook
Automatic syncronization issue
Did you try replacing the network cable .
Dec 24, 2008 | IBM ThinkPad R51 Notebook
Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
1.
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
Nov 04, 2008 | Computers & Internet
Computers & Internet Logo
338 people viewed this question
David Payne
David Payne
