Question about Sony STR-DA5000ES Receiver
Shutdown 10 second
When i turn and on signal sign protectot and than shutdown power.
    Brigadier General:
  • 6,966 Answers
The display "PROTECT" and the auto-shutdown is indicative that the Sony STR-DA5000ES senses an internal fault and powers off automatically to prevent further damage. The fault may either be in the amplifier section, the power supply section and/or the logic board (mini computer).
Initially, try a full hard reset, that is unplug from the mains for a couple of hours to hopefully revert the unit back to factory default (that is assuming no hardware problem). Additionally, you may want to check the speaker and the speaker wires for any open/breaks or short.
If above steps are not corrective, you may need to seek the services of a qualified professional or a service center since this would require on-site/in-shop repair, knowledge of electronic circuitry and components, a full service manual or at the very least a schematic diagram with voltage readings, a DVM and a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 10, 2008
NHT sa-2 amplifier won't go into standby mode after 10 Minutes of no signal
Does the NHT sa-2 have it's own pre-amp? Because I'm wondering if the power off only works when it's own pre-amp is used? So when your receiver is connected it's shut off.
You could try something connected to it's own pre-amp (if it has one) and see if it goes off when there's no signal from that.
Jan 30, 2015 | Audio Players & Recorders
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
How do i keep the power on when it goes out in five seconds?
You can't. It's the systems' internal safety circuit shutting it down friend
Not an expert on those machines but it sounds like the power output stage is faulty and overheating causing a shutdown.
Needs new output stage or repair ?
Sep 14, 2014 | Boston Acoustics Avr7120 A/v Receiver
When i press the tv/sat button the display says unlock. How do you unlock it
Problem fixed,
I turned the unit off waited 10 seconds then turned it back on pressing the power button and set up button together this started demonstration mode.Let the demostration mode run till finished then turn it off again wait 10 seconds and turn it back on.This solved the problem
Dec 23, 2009 | Sony STR-DE545 Receiver
MCACC indicator flashes and unit will not power up. I need to know the reset sequence and also whether there may be any serious damage. I do not know what happened, the unit just would not turn on one day...
Try combination of ENTER and VIDEO2 pressed simultaneously, If it comes on and stays on, you are lucky, other wise it will say AMP ERROR and shutdown mining, one of the power amps is blown.
Nov 09, 2009 | Pioneer VSX-52TX Receiver
JVC Receiver RX-6040B turns it self off after 10 seconds
the amplifier is seeing a short,or the internal components like one of the output ic are causing dc to show at the speaker terminals.the speaker protect is causing it to shut down.
May 14, 2009 | JVC RX-6040 Receiver
Yamaha RX-V690 powers up and turns right off??????
Hi...
All the speakers are connected at both ends?
If so, you have a power amp electrical break.
Not an easy fix.
Jan 14, 2009 | Yamaha RX-V690 Receiver
POWER OFF/ SHUTDOWN
Hi,,,thanks for your good response...Understnding a 7.i surround system through chat is difficult...that ws why i couldnt get it right...if i was there at your place i would have solve that it in seconds...anyway you got it done by yourself thats what we wanted...thanks again
May 25, 2008 | Denon AVR-1905 Receiver
KR-X1000 Power Problems
Sorry, no freebies from what I see online. But, when you power up, does it play before it shuts down? This will help me formulate a better answer for you...accordianman
Oct 25, 2007 | Kenwood KR-X1000
I turn it on, it clicks off within a few seconds.
can you be more specific as to "plastic tabs that show signs of slight melting"? Like where are they in relation to components / power supply / heatsinks / power transformer? A first shot... it may be output power fets/transistors (one is open or shorted) that is making one or more of the speaker outputs go to the PS rail. DC shutdown. Does this receiver indicate any "overtemp" or "protect" warnings? I really need a little more specifics.
Aug 19, 2007 | Harman Kardon AVR 25 MKII
Sony STR-DA5000ES Receiver Logo
418 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
