Question about Frigidaire FRS26ZSG
Frigidaire FRS26ZSG freezer works, fridge does not.
Ideas? how much should it likely cost to fix?
  • chadbritt Jul 01, 2008
    same problem.. i have the zrg though.. I am in the process of trying the defrosting thing right now. I don't quite understand how the freezer frosting turns off the refridgerator but we'll go with it and see what happens.
I just recently had this same problem. Check the back of the freezer, behind the white metal cover and see if the coils are frosted over. Sometimes you can just look through the slots to see if there is a large collection of frost.
If so, open the freezer door and look down to the extreme lower left on the front of the freezer. There will be a small tube with slots in it. Turn it clockwise until it clicks. This is the defrost timer. Wait a minute and see if you see steam or hear sizzling noises at the back of the freezer. If so, then your defrost element is indeed working.
The unit will defrost for about 25 minutes and it should be fine after that. If it does not defrost, then chances are your defrost heater element might be bad.
If the frost re-appears several days later then your defrost thermostat is bad and needs to be replaced (about $15), (www.sears.com/partsdirect) is one of the many places you can get another.
In my case, after the manual defrost the problem did not return. The ice-over was most likely cause by one of my kids leaving the freezer door ajar allowing moist air into the freezer.
Good luck
Posted on Jun 23, 2008
  • 828 Answers
Sounds like you may have a defrost problem. Check your freezer section for frost buildup on the back wall of your freezer. I have no idea what service rates are in your area. It should be much more reasonable to repair than to replace. Parts may run between 15-50 dollars depending on the nature of which part(s) are affected.
Posted on Jun 12, 2008
Freezer works, fridge does not. The coils in the freezer wear iced over. Unplugged, thawed, turned defrost timer switch til it clicked. Plugged back in. Freezer still getting cold. Assuming defrost timer...
The defrost timer for a model FRS26ZSG is found behind the kick plate at the bottom and front of your refrigerator. You will need to pull the kick plate off. If you turned the timer then that is the defrost timer part number=> 215846602 Defrost Timer I am here should you have questions, Sea Breeze
Jul 30, 2013 | Frigidaire FRS26ZSG
We have a Frigidaire FRS202RG side by side fridge/freezer that is about 9 years old. In the last 3 months, it has begun frosting up in the bottom of the freezer with ice forming over the vents at the back....
Sounds like the fan behind the rear freezer panel has stopped working,therefore no air flow over evaporator coils causing ice built up and no cooling on refrigerator side. easy fix
Nov 30, 2010 | Frigidaire FRS26ZSG
Freezer temp is fine fridge is not cold
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 30, 2010 | Frigidaire FRS26ZSG
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
Frgidaire side by side fridge not cold freezer is good
Fan needs to be replaced. Common issue and easily done. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Frigidaire FRS26ZSG
Fridge stopped working, freezer still works
Light going out is a separate problem. If the freezer is still working and the fan in the freezer operating check for frost on the back wall. If there is frost on the back wall you have a defrost system problem.
Possible open heater, bad timer, or defrost thermostat. If the freezer is not working check for power to it. Reset the breaker if necessary.
If the light went out because of some power loss the freezer would not be working.
May 26, 2008 | Frigidaire FRS26ZSG
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
255 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
