Question about Saeco Royal Professional Espresso Machine
Saeco cappuccinatore We have a Saeco Cappucino Royal machine. The cappuccinatore doesn't draw up the milk.
Also check that the milk is cold. temperature makes a big difference. also try pulling the "pin" on the side up and down to get the milk flowing.
Posted on Jul 06, 2008
Try to clean the cappuccinatore by putting into a glass of water overnight and rinse with plenty of water - that works for me...
Posted on Oct 30, 2011
If the cappuccinatore works fine on a different machine, but not on yours, and your machine seems to create ample steam, check the size of the outlet hole on the end of the stem (called "canot" in the parts book) That orifice size should be around 1/32". They do wear out or can get damaged.
Hope this helps
Posted on Jun 17, 2008
  • 515 Answers
Have you decalcify the machine?
Calcium in rapid steam boiler can do this indication.
Posted on Jul 14, 2008
Cappucino don"t work
Make sure that, Capucinatore is pushed in all the way And cover closed tight OR,S are in place, not crystallized Vinyl tube tight Milk cold and 2% and higher Container level with unit Steam present
Jul 08, 2013 | Saeco Royal Professional Espresso Machine
Our Saeco Royal Professional has been working well but has started ejecting steam out of the steam wand and cappucino spout.
Sounds like your machine needs a new steam valve plastic. Because it is worn the part is allowing steam to come out of the steam wand when it should be closed.
Hope this helps.
May 20, 2011 | Saeco Royal Professional Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
Hope that helped! Thanks for using FixYa.
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
How can I make the milk hotter using the cappuccinator?
Yes you can make a small trick for that. You can use a sqweeter on the milk silicone hose so the milk can flow with more dificalty as long as you can see milk flowing this can be up to 78 C . You should keep the cappuccinatore very clean since you will need the steam to come as easy as possible
Feb 04, 2010 | Saeco Royal Professional Espresso Machine
Cappuccinatore does not draw milk
Hi
There should be a little knob on top of the cappuccinatore. It is what causes the milk to flow up the tube. When it is steaming, rotate the knob slowly until the milk starts to flow up the tube. You can fine tune the knob to get the best foam.
If you are missing the pin that has the knob on it, there will be a small hole in the outside top of the cappuccinatore. If you don't have hole and a knob, it is broken off and you need to replace the cappuccinatore
Oct 19, 2009 | Saeco Royal Professional Espresso Machine
I am looking for a replacement cappuccinatore automatic milk pin
check out the enclosed link:
http://www.cafeparts.com/SearchProducts.asp
Let me know if this helps.
Have a great day!
Mar 06, 2009 | Saeco Royal Professional Espresso Machine
Cappuccinatore Milk Temperature on Saeco Royal Pro Machine
Hi
First open it up and run it without any milk attached until just mostly steam is coming thru. Turn off - then drop the tube into a jug of milk which is locted below the outlet. If its steaming, the milk will be heated up ok - it may need flow adjusting - lift the thin 'plug' near the tube up and down to adjust flow. You can add to the froth by lifting the tube out of the milk for a moment then back in again a few times.
To clean the unit just run clean water tru as tho it was milk until it comes out totally clear (about 1/4 cup). For hygiene sake make sure the tube is wiped clean on the outside with a clean paper each and every time when finished.
You can flush your main coffee lines out by making out its doing a large preground coffee - but don't put any preground in.
Select preground - select large coffee and go. Pays also to remove the brew unit and wash in warm water once a week - saves coffee goo building up and causing it to stick.
Feb 21, 2009 | Saeco Royal Professional Espresso Machine
Saeco cappuccinatore not taking milk, instead blowing some steam into milk
Try this, the valve diagram shows that you twist the knob, but you left it up and down to adjust the flow. You could also check that the container you have the milk in, is lower in height than the cappuccinatore to help it siffin the milk up from its container. Make sure the cappuccinatore is fitted correctly pushed in fully and half fill a cup with milk and pull the valve adjuster up a small amount and push the button. It should start pushing steam out the cappuccinatore and then within a few seconds it should start siffining milk up the tube.
Cyril
Sep 27, 2008 | Saeco Royal Professional Espresso Machine
Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
Nov 10, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Royal Professional Espresso Machine Logo
635 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
