Question about Acer AL1715 17" LCD Monitor
Menu window Hi there I hope you can help me. The menu window keeps popping up and its very annoying. It did the same thing quite sometime ago and then it just stopped and now its back again.....grrrrrrrr thanks in advance L
  • Anonymous Jun 28, 2008
    same problem of menue opening up.. I have not found solution!
  • 472 Answers
It can be something as simple as a faulty contact switch not releasing correctly.
Try this in order and post back the results.
  1. Unplug the monitor from the wall for 10 minutes. This can help correct issues that can be inside the control circuit of the monitor. It is a fine line between something being pressed and not being pressed to an electrical device..sometimes they just misunderstand the signals.
  2. Tap the button that activates the menu several times. Then tap between that button and the next button on the bezel. Do that on both sides to help release the button if it's stuck
  3. If those fail, then drop it to your local tech and get them to replace the switch. This should not cost alot to have corrected.
Posted on Jun 16, 2008
How do I remove unwanted pop ups?
Internet pop-ups can be an annoyance. These windows are usually associated with different forms of advertisements and at times can include viruses that can infect the computer. Pop-ups do not have to be a part of computer use if the user does not desire this distraction. There are ways to stop pop-ups and prevent them from appearing unless desired. Pop-up blocker allows the user to block these items and select which items to allow.
Open Internet Explorer. Click "Tools" from the menu bar. Tools can be found on the bar that lists "File, Edit, View, Favorites, Tools, Help" directly beneath the address bar. Click "Internet Options" from the "Tools" menu. Click the "Privacy" tab in the "Internet Options" box. Click to check the box that says "Turn on pop-up blocker" in the "Pop-up Blocker" section of the menu. Click "Apply" to save changes. Click "OK" to close the "Internet Options" box. The computer will now block all pop-ups from websites. If downloading items from the Web, the computer will ask whether you would like to allow these items to be opened. Hope this helps.
Jan 16, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Removing Cyberlink Power DVD Registration Pop Up
Are you using Cyberlink Power DVD version 6 or later.
these version keep popping the registration menu quite often which makes it somewhat annoying if you don't want to register it.
here is how to stop the pop up.
Close the Cyberlink Registration pop-up and shut down the program.In Windows XP, Go to "Start" > "My Computer" > "C drive".
In Windows Vista and 7, Go to "Start" > " Computer" > "C drive".Click on"Program Files" > "Cyberlink" > "Power DVD"> OLRSubmission".
Right-click on the "OLRSubmission" folder and choose "Rename".
Type"Submission" in the box and press "Enter" to set the name.
This will disable the pop-up.
on Mar 03, 2011 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Annoying adverts on screen
Hi Ken,
Block the pop-up windows by:
  • Go to tools option on browser menu.
  • Click on options.
  • Select on content.
  • Check the 'block pop-up windows option' by clicking inside the box.
Hope this helps.Thanks!
Jan 01, 2012 | Dell Computers & Internet
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
NEC 1770 monitor
click Menu, Menu/Tools, scroll down to Resolution Notifier and choose Off
Apr 27, 2008 | NEC MultiSync 1770NX 17" LCD Monitor
Actually I have an ipaq hx 2495b with mobile 5
go to
File explorer
My device/windows
start menu
Program
delete the icon(s) you don't need
Oct 03, 2007 | Compaq iPAQ H3630 Pocket PC
Acer AL1715 17" LCD Monitor Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
