Question about Garmin Rino 120 2-Way Radio
Garmin Radio Rino 120
Just pulled out my Rino 120's to use after storing them for about 2 years. Put in new batteries. One radio seems to be working fine. 3 bars for battery strength. The other radio is getting warm/hot to the touch and down to 1 bar for strength after 1/2 hour. In the previous post you something about bad I/C. How do I get that checked out. And is there anything that can be done to fix it? The radios have barely been used. Thanks
3 Suggested Answers
Neto
  • 123 Answers
SOURCE: Batteries in my Rino 120 don't last very long
Check if the Ptt buton is not pressed by itself Check if all the features are running well because heat is not a good sing.
Posted on Aug 02, 2007
  • 3 Answers
SOURCE: Rino 120 - Disabled WAAS
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
Posted on Nov 28, 2008
How come the garmin 120 radio isn't compatible with standard Motorola walkie talkies
When programmed to the same frequency and code settings the Garin Rino 120 should match the Motorola TalkAbout line of radios. They are all using the same UHF FRS/GMRS frequencies. Here is a link to the Garmin user guide where you will find the frequency charts on pgs. 100-102: http://www.uky.edu/~jmlhot2/courses/for480/Rino120_OwnersManual.pdf
Motorola TalkAbout user guides can be found at: http://shop.giantintl.com/Manuals.asp
Best regards.
Nov 20, 2014 | Garmin Rino 120 2-Way Radio
Instruction
Download or view the .pdf Rino 120 Owner's Manual here........
http://www8.garmin.com/manuals/Rino120_OwnersManual.pdf
Dec 10, 2008 | Garmin Rino 120 2-Way Radio
LED does not work
you have damaged the screen and it will likely need replacement. there is one other possibility... you may have loosened a connector inside the radio... tap it gently with your finger to see if there are any changes in the display
Robert
Sep 20, 2008 | Garmin Rino 120 2-Way Radio
Turn it on - black screen
Dropped the rino 120 and the led is blank but radio works
Sep 01, 2008 | Garmin Rino 120 2-Way Radio
Garmin 530 gps radio
I am guessing that the unit is out of warranty. if this is the case go to http://www8.garmin.com/support/outofwarranty.html to handle your repairs. while I have not personally sent anything to Garmin, I don't expect you to have any problems. Garmin is a highly recognized company for both thier products and for there service.
Pat
Aug 12, 2008 | Garmin Rino 120 2-Way Radio
Rino 120 Send note
This sounds like the new firmware version may not work on the
older model.
The best solution would be to contact Garmin
Product support at (913) 397-8200 or 1-800-800-1020
Monday - Friday, 8am-5pmCDT or by email at sales@garmin.com
Pat
Aug 09, 2008 | Garmin Rino 120 2-Way Radio
Garmin 120 will not turn on
i talked with garmin tech today, he said to hold the button below talk, and the wheel and the power at the same time to master reset....it did not work for me but it might for someone else
Apr 03, 2008 | Garmin Rino 120 2-Way Radio
Broke rino
I had a similar problem with my account.
I pushed the one batteripolen down as it started up again.
Mar 12, 2008 | Garmin Rino 120 2-Way Radio
Garmin Rino 130 no Power
There first 2 main thing to check..... the off on switch.... and the fuse. Insie the radio there is a very small fuse.... its a surface mount component fuse... very small. That could be the problem. Also check the contacts on the radio..... if you have a way of connecting the correct voltage directly to the radios power terminals using jumpers I would definatly do it. Your most likly going to have to take the raio apart and and connect the battery to trace the power through it. The small fuse will be one of the first components after the positive power input. If this seems too much..... bring it to a radio shop... they can do all this quickly
Sep 20, 2007 | Garmin Rino 130 (14 Channels) 2-Way Radio
Garmin Rino 120 2-Way Radio Logo
89 people viewed this question
Top Garmin Radio Communications Experts
TO Lady
eradiostore
eradiostore
Computer Repairing
Computer Repairing
Are you a Garmin Radio Communication Expert? Answer questions, earn points and help others
