Missing Q key on keyboard
The Q key broke off my keyboard and I don't know where to begin to find the parts underneath the letter to hold it to the keyboard! Can u order these from somewhere?
  • 1 more comment
  • abcdurrett Jun 10, 2008
    Thanks!! Why do they have to make everything soooooo expensive!! I might as well buy a new computer!!!!
  • Anonymous Dec 06, 2008
    the e key on mine has broken off and i cant find a replacement anywhere
  • Anonymous Mar 15, 2009
    missing R on keyboard
My (at) key will not work on my dell laptop if i press the shift i get the semi colan is this a mechanical fault ?
Posted on Dec 17, 2009
You have to buy a new keyboard my #2 broke off and i had to order a new keyboard because there is no replacement parts unless you make one
Posted on Jun 10, 2008
Why when i type some of the letters dont show up
That would be due to a faulty keyboard, due to old age, lifespan of keyboards or maybe during typing you are missing the key and the keyboard results in not recognizing that command. If it is happening with a deliberate press (even when you press harder) it is due to the contact panel underneath that is making your letters appear. Maybe a cleanup of dust and stuff will fix it, or as a more expensive solution a new keyboard. Ebay ranges keyboards for vaios at around 25dollars
Oct 22, 2012 | Computers & Internet
Some keys on keyboard not working on my acer aspire 5253-B2692
Im going to assume you didn't spill anything on the keyboard here...The best solution for you is to take the keyboard out and reseat the ribbon cable that holds it in place. Sometimes those cables get just a little bit loose, but a little can cause a lot of trouble as you can see. Let's see how much trouble...open "notepad" or some other writing program you have....type every single letter and number and see which ones you are missing. Let me know if there are any others that don't work....then we'll go through the process of taking the keyboard out and reseating it.
Jun 11, 2012 | Computers & Internet
Number keys don't work right above letters on keyboard
You have to hold the Fn key, usually blue in the lower left corner of keyboard, for the numbers above the letters to work.
Good Luck,
John Vickers
Sep 18, 2011 | Computers & Internet
Need a replacement letter J key for compaq laptop keyboard. Can I purchase one through you via Paypal?
Unfortunately we don't sell computer parts here. We only provide technical support services. However, since you need this part you can order this through THIS LINK. I just don't know if they accept payments through PayPal though.
Jun 04, 2011 | Compaq Keyboard
Hello, I was needing to know how to take apart a Toshiba A505D-S6958 laptop's grill so that i could clean underneath the keyboard ?, is this an easy process ?, or is it more to it than I'm thinking...
It is not too hard and it can be done. If you just need to clean it, you can use air can compressor to clean it the surface and underneath the keys because dust can't get into underneath keyboard, therefore, you don't need clean underneath part unless you need to replace the keyboard.
But if you still really need to do it (for learning experience), then yes, you can do it.
All you need to have it a flat and philip screwdrivers. Be gentle when do it, you might need to take picture of keyboard before it been removed so that you match them when you put keyboard back.
Use flat screwdrive to remove the top part of you keyboard and underneath you will see 4 or 5 screws that hold keyboard, just unscrew them. Here is the link for more information.
www.youtube.com/watch?v=GcM9knr_P4Q
For more information about your laptop parts and location, see
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2346354&rpn=PSAQ0U&modelFilter=A505D-S6958&selCategory=2756709&selFamily=1073768663
Click on user's guide
Good luck
Thank you
May 13, 2011 | Toshiba Computers & Internet
Keyboard is missing the D key what should I do
Hello
I would suggest that you just try to find the spesifick letter you need, a new keyboard for that device will cost you a new laptop. Go to any computer hardware store near you, they usually have odd parts that they give away, maybe you are lucky. Otherwise just contact the manufacturer and order the letter you need. Hope this can help you.
Best regards
Andrea
Nov 01, 2009 | Computers & Internet
Spilled a little rum on the corner right side of the laptop and now had to get an external keyboard because the laptop keyboard types multple letters and numbers when keys are pressed.
If that is the case you can purchase a new keyboard off ebay for $20, remove the screws holding it (will either be underneath laptop or right above keyboard) and replace.
Mar 09, 2009 | Toshiba Satellite A105 Notebook
DELL 9300
pop the key off and look underneath, there should be a rubber nipple thing that pushes down and spings up, this is what holds the key up and without it, it wont make contact to tell it you pressed " P" If its there, you can try setting it back in place and it should be fine. If its missing, then your out of luck and un-fortunatley, will have to ge a whole new one just to fix it.
you can look online or get one from ebay that is sold as parts. then keep both keyboards in case it happens again, you will have spare parts.
Let us know
Dec 04, 2008 | Dell Inspiron 9300 Notebook
My problem with key board
try cleaning your keyboard. There may be some dirt or other debris embedded underneath the keys of your keyboard. Here is a website address that intructs you on how to clean your keyboard thoroughly.
http://www.helpwithpcs.com/maintenance/cleaning-keyboard.htm
May 24, 2008 | Acer Computers & Internet
Computers & Internet Logo
793 people viewed this question
David Payne
David Payne
