Question about ASUS M2V-MX SE AMD AM2 Socket AM2 2000 MHz PC2-6400 mATX Motherboard Retail
Cpu problem hi i turned on my pc today which did not boot and got a voice message system failed due to cpu overclocking tried everything i can think of to get it going moved ram took out battery and put it back,tried reset jumper but nothing any ideas?
Reformat
Posted on Jun 10, 2008
Try to put operating system in computer comes up with overclocking failed error how do i reset or fix overclocking problem
hit F1 or DEL right at boot repeatedly until it enters bios. look for cpu/frequency, perhaps underneath "chipset" or "advanced" settings. lower the cpu/frequency a little, until it boots, or look for "auto" settings for the cpu/frequency and ram speeds.
Nov 23, 2010 | EliteGroup 945P-A (945PA11) Motherboard
System failed due to cpu overclocking. Not setup for overclocking in the bios.
Reboot, and enter BIOS SETUP mode.
Choose "Load Default Settings".
This will "undo" any overclocking of your motherboard and of your CPU.
Sep 20, 2010 | ASUS P4P800-E Deluxe Motherboard
Hello When trying to turn on my pc I hear a mesage from the voice genie, saying that there is a problem (your CPU might have a problem, I think). I have amd sempron 2500+ socket a albatron kx18d...
Have you tried removing the Cmos Battery? if not remove it and leave it outside for few minutes (5 mins) and reinstall it (do this while the Machine is off). Boot the system again. It's also important to re-seat all the components like, front panel connectors, usb connectors, audio connectors, hard disk, cd/dvd rom, processor, Ram, fan, power connector, etc... and clean whatever you can and then reconnect or reinstall them. If there's no actual cpu failure or motherboard faulty, your problem will be fixed.
I wonder where's that Genie voice came from :-)
Good luck.
Thanks for using FixYa.
Aug 18, 2010 | Albatron K8T800 (K8X800 PRO LL)...
System fail due to cpu overclocking, voice message on reboot, after turning the adaptive overclocking feature on in the bios. I cannot clear cmos and get back into bios to turn it off again. I have tried...
Disconnect the power cable, press and hold the power button. Open the case, remove the cmos battery and short the cmos battery connectors (just touch both the metal tabs center and edge at the same time) with a screwdriver. Replace cmos battery, reconnect the power and power on. This should reset the BIOS to default settings.
Apr 01, 2009 | ASUS A8V Deluxe Motherboard
System failure due to cpu overclocking - voice message
check ya system is not to overclocked and reinstall ya system settings and check ya virus settings and possibly ya os
Apr 01, 2009 | Abit AV8-3rd Eye Motherboard
I get a Post audio message on boot up/but no bootup
i have just thrown out 3 ASUS boards for various problems. they seem to last approx 18months before they die.
video output goes wrong, cpu socket errors, all sorts of problems and a rubbish tech support at ASUS does not help.
Feb 23, 2009 | ASUS P4P800-E Deluxe Motherboard
Warning message at boot up,non-responsive keyborad
Try this! Open your CPU there you will find CMOS battery remove it and reinsert and there will be a BIOS pin remove it and reconnect. Now Switch On the system.
Jan 13, 2009 | Micro Direct (SYSMDBGAMBASE004) PC Desktop
I get a message over the speakers System failure from CPU overclo
Hi there
Try resetting the CMOS either by removing the battery from the motherboard for 20 mins and make sure the power cord is removed from the back of the machine. When you put the battery back you will have to set the time and date again
Good luck and kind regards
Jan 05, 2009 | ASUS P4P800-E Deluxe Motherboard
Home built 4 yr old pc wont boot
You have voice message telling you CPU test failed , but does it BEEP at all ? if you have a Beep code then replace the CPU fan ( when CPU gets too hot it will either shut down or the PC will not boot up at all )
Jul 23, 2008 | Intel Motherboard
P35 Neo2 Motherboard Jumpers
a quad Q6600 is manufactured @ .273 overclocked from the factory. at no time should this cpu ever be overclocked anymore unlessd you are using a watercooling system that keeps the cpu @ 69 degrees for stability. anything else will burn it out. lala linda
May 31, 2008 | Intel Motherboard
ASUS M2V-MX SE AMD AM2 Socket AM2 2000 MHz PC2-6400 mATX Motherboard Retail Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
