Question about Kyocera Mita FS-1920N Laser Printer
PRINTER ERROR F030
Our invoice printer has come up with error code F030 this has happened before and someone stepped us through the menu keys over the phone to clear it.Unfortunately i no longer have this persons number.We have already been charged a $181.50 service fee and told we need a new main board, this happed last time with the same outcome but was fixed over the phone.
You are pretty close to the mark, after having the company come out twice and quote circuit boards / cards etc. We had worked out that the issue was actually the file that we were originally trying to print.After clearing the printer drivers on pc it had cleared the error on printer. Was just about to be hit with an enormous bill from the printer company that came out and never thought to check the printer drive on pc first.
Posted on Aug 14, 2008
Check the file that you are trying to send. It's either in the file or application that you are using to creat the file.
Tip
How to fix cd/dvd rom error code 39
SOLUTION -
Step 1 - Go to "START MENU" and oper "RUN" and type regedit and hit the enter key
Step 2 - Take registry backup (Registry Backup is must, incase something wrong happens then previous settings can be rever back)
Step 3 - Nowgo to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet >Control > Class > {4D36E965-E325-11CE-BFC1-08002BE10318}
Step 4 - You will find this registry keys UpperFilters, LowerFilters, UpperFilters.bak, LowerFilters.bak
Step 5 - If any of the above keys shown in step 4 are listed, right-click on them and choose Delete.
Step 6 - After deleting the keys, close the Registry Editor
Step 7 - Reboot your computer
Step 8 - Open My Computer and check if CD or DVD drives is listed.Also openDevice Manager and verify that the yellow exclamation and error code onthe CD or DVD drive is gone.
for more information click on this link
CD/DVD drive not working
on Sep 01, 2010 | Computers & Internet
Tip
Brother MFC 8440 showing error code MACHINE ERROR 6A or 6E
Hi.
Both errors are signalling a temperature problem in fuser assembly.
The solution below applies to several Brother models. Depending on the model, the reset procedure may be different.
Brother Error 6A means that the thermistor located in the fuser assembly did not detect that required temperature had been reached in valid time.
First you can try entering in maintenancemode and clearing the error. If that does not work, that means that the thermistor, the lamp, or the whole fuser assembly must be replaced.
Error 6E is similar. 6E is diplayed when thermistor detect that the fuser temperature is not going up at least at 2°C every for 5 seconds.
As for 6A, first reset the code. If the error does not clear the fault can concern the thermistor, the fuser lamp or the power supply to the fuser assembly.
To reset the error code follows these steps:
1. Press MENU *,2,8,6,4 . Press keys within 2 seconds.
2. The machine beeps and display shows “maintenance".
3. Look for Init or Reset on menu, and enter the corresponding parameter.
4. To exit press 99.
This procedure above usually works on MFC-8xxx model. On other models you may need to do the following:
1) Unplug machine.
2) Hold down menu key. Plug in machine.
3) Release menu key.
4) Enter 91
5) Enter 99
or:
1) Disconnect the printer power cord.
2) Hold down the menu key while plugging in machine at same time.
3) Enter 99 while holding down menu key
4) After menu says " wait" push the stop/exit button to get out of the maintenance mode.
If that does not work, it means that the fuser assembly must be replaced. Here the part for MFC-8440: Genuine Brother Mfc8440 Fuser Assembly.
Regards.
on Apr 08, 2010 | Brother MFC 8440 All-In-One Laser Printer
Kyocera FS-1920, error F030:0077538
i've been working on kyocera's for about 4 years. now..this error is not good..it's a general system failure..only solution is replacing main board.
contact me if you need a part #.. I can look it up for you
Feb 01, 2010 | Kyocera Mita FS-1920 Laser Printer
I suddenly got an LCD Error E000 in the middle of copying. I have followed the reset procedures outlined by Canon. I have powered it off for up to an hour but still get the error messages. I have reset...
Make sure it has its own dedicated power and not sharing power with any other device. If the power checks to be good, follow the steps below.
Perfrom a Printer Reset. A Printer Reset can be done by:
1. Enter Service Mode by pressing the ADDITIONAL FUNCTIONS key, then the # key.
2. Scroll through the menu using the arrow keys to the left or right of the SET key.
3. Find #7PRINTER and press the SET key.
4. While in the the #7 PRINTER menu, use the arrow keys and find #4PRINTER RESET and press thre SET key.
5. A selection of either YES or NO will appear, use the arrow key to the LEFT of the Set key to select YES.
6. After YES has been properly selected, unplug the machine and plug it back in.
Following these steps can reset this code.
Oct 20, 2009 | Canon imageCLASS D860 All-In-One Laser...
E000
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003. Here's the definitive reset procedure Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
please rate my answer after trying if satisfied
Jul 06, 2009 | Canon Image Runner 1630 Copier Copier
Call service engineer Kyocera
power down unit and power on... if same error get a surge protector or power conditioner... plug unit into it and then power down and power up... if same error replace the memory card in the unit... if same error replace memory board...
Apr 10, 2009 | Kyocera Mita FS-C5016N Printer
Kyocera fs1920 problem
F030 = main controller PCB System Error (frimware upgrade required)
do you have access to a Compact Flash Card & a Card Reader / Writer?
or is the printer connected via Parallel?
Nov 08, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
Tally T8106
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  • Power the printer on while holding down MENU/ENTER key
  • Release the key when the display shows "Utility Menu Clear FC. Roll"
  • If you have replaced the FC Roller then select this option by pressing MENU/ENTER key, if you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  • When one of these options is selected by pressing MENU/ENTER key, the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute" by pressing MENU/ENTER key again the display will change to "Execute"
  • Press the MENU/ENTER key again after 10 seconds the display will change to "Completed Clear FC. Roll / belt CG"
  • Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jan 28, 2008 | Tally T8106 Laser Printer
Kyocera Mita FS-1920N Laser Printer Logo
2,659 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
