Ligned sponge located below the printhead. Should you
have a paper jam and want to pull out the paper from inside the printer,
there is a possibility that you will also pull out some parts of the
sponge. The improperly placed sponge may then cause the paper to jam
again.
Solution
If you realize that the sponge is not in its proper position, you will
need to push it to the correct position (as seen on the images below).
Then, when paper goes through the rollers, it will not be blocked by the
sponge.
Properly placed sponge (Click for larger a view.)
Improperly placed sponge (Click for a larger view.)
