Question about Whirlpool Refrigerators
The refrigerator is not getting cold to it's recommended settings.
  • 828 Answers
Check for a frozen coil in the freezer. Air from the freezer supplies the cold air to the refrigerator section for cooling. If frost is on the back wall of the freezer section you have a defrost system problem.
Frost on the back wall of the freezer indicates timer or heater circuit failure.
Posted on Jun 10, 2008
I have a whirlpool refrigerator model wsf26d4exb00. the refrigerator side is cold only on the bottom but the top selves are warm
Make sure you condensor fan is running. Our gets clogged up with dog hair sometimes and when the fan cannot run the fridge cannot cool.
Aug 19, 2014 | Whirlpool Refrigerators
Why is my frt18s6awx not getting cold enough in freezer & fridge?
Good Afternoon Friend,
I understand that your Frigidaire freezer, model# FRT18S6AWX, is not getting cold enough in either the freezer or refrigerator. I suggest changing the settings to a colder setting and give it 24 hours to stabilize at the set temperatures. Also, I recommend cleaning the toe grille and condenser coils. You can do this by taking the toe grille off and cleaning it with soap and water and rinsing it thoroughly with water. While the toe grille is off, get your vacuum with extension, and vacuum underneath your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRT18S6AW Top Freezer...
I have a Sharp Frost Free refrigerator Model SJ-68LM-C2W. I have noticed that both sides of the refrigerator are very warm. Temp. is set at 4. The refrigerator is fully stocked and the problem is that...
Normally when the refrigerator side freezes, it's because of an air flow problem. It can be caused from a stuck or defective air diffuser, a control board or sensor if this model has them or a thermostat, if it has one. You can check the temperature in the freezer section, to see if it's getting too cold (below zero). To check the temperature, place a thermometer between some packages. Air temperature is not a good check. If it is too cold, it can also cause the fridge section to get too cold. Usually, adjusting the control, to a slighlty warmer setting, will correct this.
Jul 31, 2011 | Refrigerators
My refrigerator wont get cold and it is on the highest temperature possible the freezer is working fine. its still makeing ice but its just that the refrigerator wont get cold. its also 10 years old.
Always set the controls to their "normal" recommended setting. Changing them will not work. Is there air blowing from the freezer? The freezer fan may not be working. Or if it is, possibly the air flapper could be stuck closed not letting air flow into the refrigerator.
Dec 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Getting to cold sometimes freezes food
Turn settings to 3 and C or recommended factory start settings. Turn down if still too cold.
Sep 11, 2009 | Dometic RM2852 Refrigerator
Amana DRB2201CW refrigerator does not get cold
You may have an obstruction in the air vent from the freezer compartment to the frig .there should be an airflow adjustment next to the thermostat. Middle setting is recommended. Since you say the freezer is working properly, I cannot see any other possibility. hope this helps.
Jul 28, 2009 | Amana ARB2257CSL Bottom Freezer...
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ge refrigerator not cold enough
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 11, 2007 | LG LRSC21934 Side by Side Refrigerator
Refrigerators Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
