Picture spins Hey firstly thanks for having this site... Our TV shows a picture, but it is spinning vertically, just like the good old days. :( It also has a very slow spin in the horizontal picture. Now years ago we could adjust this, but what do we do these days with modern technology? Thanks in advance for your thoughts. Rick
  • Rickk2 Jun 10, 2008
    By the way this is a Sony Trinitron KV-F29SF11 if this helps.
    Thanks again for you attention.
    Rick
    Genius:
  • 1,554 Answers
You cant adjust it is synced to the 60cycle of house current.
the cheapest you can try it to replace the HOT (horizontal output transistor ) its cheap and easy to get ,
its on a large heatsink near the HV flyback.
but it is work and not an easy job for some.
dangerous for some too.
they flyback can be leaking too or other caps around the HOT is the issue and the fix won't or may not last .
there are kits available on sites even on ebay for these fixes.
Posted on Jun 10, 2008
White screen and black vertical lines over half of la26b450 model tv screen
Good day!
that problem is on the cable please try to play dvd or recorded tv shows.
if you play dvd or recorded shows and picture is normal
try to check the connection of your cable and try to touch the connector and move it gently then see the picture of your TV if there's changes
thank you
May 29, 2011 | Televison & Video
TV picture vertical drift.
Symptoms shows weak capacitors in deflection circuit.
Please mention model and brand of your TV.
How old is your TV?
Thank you.
Oct 07, 2008 | Televison & Video
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Picture junping
You possibly have a cracked solder joint in the vertical circuit, possible the vertical Ic itself. You'll have to remove the board and look carefully at the soldered connection of the vertical circuit and see if any are ring cracked. Some soldering should fix the problem. If you let the problem go too long the heat these cracks generate will eventaully short the vertical Ic..
Bill
Dec 04, 2008 | Emerson EWF2004 20" TV
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
No Picture, no sound, spinning up noise
vertical ,horizontal or power suppy
Dec 02, 2007 | Sony KV-32FS13 TV
Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
Jun 26, 2007 | Philips 27PT6441 27" TV
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Open Questions:
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
