Samsung SCH-u520 Cellular Phone Logo
Posted on Oct 28, 2010
I accidentally selected the programming of NAM2 on my samsung freeform and it locked the phone and I don't know the code
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1441
Points
8
Http://www.youtube.com/watch?v=hz-oPn1yTuo
Go here this is how i fixed it
13helpful
When you change your setting to nam 2 how do you unlock your phone
Go to the keypad, type #43574357* (this number should work) and select system info, and it will display your nam2 phone number on the first (top) row labeled "MDN." The last four numbers is your passcode.This solution ONLY works if you've accidentally set your phone to NAM2 (which means that you've reprogrammed your phone to a completely different phone number, and if you've set up a passcode, that too is changed). Once you've found out your new number and passcode, you are not yet finished, because your phone is still programmed to NAM2. To fix that, you must go to your "Phone settings" and find "NAM select." Then you select NAM1 (and your phone will restart again and prompt you with your OLD passcode, if you set up one). Your phone is now fully functioning again!
2helpful
3answers
Need samsumg sch-r360 un lock
Is your mobile is SCH-r360 or r360 Messenger or r360
Freeform II ??? you can unlock your mobile by unlock codes..the safe and best way of unlocking is by unlock codes and my personal request is that don't go for software unlocking because sometimes the software might get corrupted and may your data will be lost due to that,its my bad experience so I went for unlocking by codes from superunlockcodes and unlocked.you can too try but see to that whether your country and provider is listed..because for some service only codes are available..check with that and if your country's provider is listed then get codes and unlock your mobile..
Oct 03, 2011 • Cell Phones
3helpful
2answers
I accidentally locked my Samsung reality by clicking NAM2 my phone restarted then put on a lock code I've tried the last 4 digits of my number and my own password neither one works. How do I unlock it?
You can Unlock the mobile phones from the Security Lock(Password) lock using the Master Reset Code,You can get the Master Reset Code at Reliable Cost here
http://www.onlinegsmunlock.com/unlocking-services/rs7wp6/ and Unlock the mobile from the Security lock,You Can Check whether Your model in the List!!!!!!!!!
Nov 14, 2010 • Cell Phones
7helpful
YoYo is a spammer on FIXYA, permitted to post the same post infinitely for some unknown reason.
the following website explain the complete process of how to reset your Metro PCS Samsung Freeform II SCH-R350
http://cellrb.com/metro-pcs/how-to-reset-samsung-freeform-ii-sch-r350/
2helpful
Switched to NAM2 and do not know the lock code.
Dial *22899 and press SEND to program the phone.
after it has finished downloading the programming information, the phone will reset.
The Lock code will now be set to the last 4 digits of your phone number.
when you have finished, be sure to switch back to NAM1 and dial *22899 again to re-program it.
7helpful
3answers
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
How to bypass phone 4 digits lock code or how to get the lock code if it wasn't the last 4 gigits of the phone number and I don't know what it is?
If you put your phone on nam2, like i did, you need to call samsung's hotline. customer service can provide you with the nam2 access code. Verizon would make you pay 59.99 to get a reflash to basically do the same thing. samsung's number is on the back of your phone
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
1helpful
2answers
Cant unlock my phone
If you know your original lock code, take it in to your service provider, each code is diffrent and can only be programed manually, if you dont know your original lock code you will have to sacrific all info pics,mess,numbers, etc. by a reset... I can guide you through the steps to erase all if you lost your Unlock code, or switch back to nam1 if you know your lock code, ( when you switch back, if security is on automatic lock, password is required) intial programing code is not your Unlock code.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
