Question about Microsoft Office Professional 2007 Full Version for PC
Error when testing my pop3 account
None of the authentication method supported by this client
  • Tim Babcock
    Tim Babcock May 11, 2010
    How are your pop3 settings configured?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Contact your ISP, as very often there is not support for a specific type of account, especially if you are out of your service area. This type of problem is very dependent upon the ISP. Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 16, 2008
Outlook: None of the authentication methods supported by this client are supported by your server
For more information about repairing or configuring your Outlook email account, click the following link:
https://www.pstrepairkit.com/
Regards,
Arnold Warner
Oct 17, 2016 | Computers & Internet
How do I change my wife's email user name?
Here is Microsoft forum on the error code
Windows mail error code 0x800ccc90
Cause for this error is generally The client is trying to use Secure Password Authentication and it is not enabled on the Exchange Server computer. To verify what form of authentication the Outlook Express client is using, in Outlook Express, on the Tools menu, click Accounts, and click the Server tab for the account that failed.
Also when your adding the 19 to the email it is creating a whole new email. So if you created the new email. then please refer to this link
POP3 Outlook Express error 0x8000CCC18 and Exchange Server
Aug 10, 2014 | Microsoft Outlook Express
I cannot retrieve my mails or send emails, what is it
do you have an internet connection ? what email program ?
Doing a little detective work can save you a lot of extra hassle. If you're having trouble sending email from clients like Outlook, Eudora and other POP3/IMAP software, please check the following issues:
Correct Passwords
Verify that all password information is correct.
We get many requests that simply turn out to be a password error.
When cutting and pasting be sure to watch out for extra spaces.
Mail Server (SMTP) is Offline
Your server could be running and serving both POP3/IMAP but not providing SMTP service. On many systems, the program responsible for POP3/IMAP is not the same as the one for
open an email click tools accounts mail then on the right select properties you should see your email adress then click on servers you will see
POP3 should have mail. with your provider ie: mail.bigpond.com
and outgoing mail the same mail.bigpond.com
SMTP. As a result, you may be able to check mail but not send.
Try restarting your server or email service from your control panel.
ISP Blocks
An increasing number of ISP's are blocking port 25, the port used to send email.
Many of the major ISP's, including NetZero, MSN, Earthlink, AT&T, Comcast and Verizon, block port 25 in an attempt to control spam. If your ISP blocks port 25, then you will be unable to send email out of your server.
This is not a server problem but a direct block by your ISP. We can often work around these blocks by configuring your mail server to listen to additional ports.
You can test if port 25 is blocked by using a telnet client to connect to port 25.
If you connect successfully to port 25, you will see your mail server's banner.
This will list some information about your mail server.
If you cannot connect to port 25, then either your mail server is down or your ISP has block port 25.
ISP blocks are becoming an increasing problem.
Generally, once password issues have been ruled out, sending email is all or none. If the mail server is down, no one will be able to send email.
ISP blocks will only impact those clients behind that ISP's network.
Server Load Throttling
Many SMTP servers will begin to reject email if server loads are too high.
If you have root access, you may want to login and run "uptime".
This will tell you your current load averages.
Many systems stop responding to email requests if loads exceed 12 for a five-minute period.
If the load does not decline to below 4 within a few minutes, then you may have a service performance issue.
SMTP Authentication
Most email servers use one of two mechanisms to determine if a user is permitted to send email.
The first method, "POP before SMTP", requires that the user first check their email before they can send.
If a user cannot check their email, then they will not be able to send.
Try restarting your POP3/IMAP server and testing again.
The second and preferred method is called SMTP Authentication.
This method should be used if your system supports it.
Current Ensim, Plesk and cPanel servers all support SMTP AUTH.
To use this feature, the user must check configure their email client to use authentication for sending mail. In Microsoft Outlook, there is a check box called "This server requires authentication."
That box should be checked.
hope this helps
Sep 17, 2012 | Dell Latitude D 600/610
Im trying to set up the hotmail on the samsung 5560
TO SETUP MAIL CLIENT TO ACCESS WINDOW LIVE HOTMAIL ACCOUNT,USE THE FOLLOWING HOTMAIL POP3AND SMTP CONFIGURATION SETTING.
INCOMING SERVER(POP3): pop3.live.com
INCOMING SERVER POP PORT:995
INCOMING SERVER POP SSL ENCRYPTION:YES(ON OR REQUIRED)
OUTGOING SERVER:smtp.live.com
OUTGOING SERVER PORT:25
OUTGOING SERVER AUTHENTICATION:YES(USE POP USERNAME AND PASSWORD OR HOTMAIL CREDENTIONAL)
OUTGOING SERVER TLS OR SSL ENCRYPTED CONNECTION:YES(ON OR REQUIRED)
TIPS: OUTGOING SERVER OF HOTMAIL ALSO SUPPORTS PORT 587,USEFUL FOR PEOPLE WHO ENCOUNTERS ERROR FOR SMTP DUE TO ISP BLOCKAGE OR ANY OTHER REASON
USERNAME: YOUR HOTMAIL ID
PASSWORD: YOUR PASSWORD FOR YOUR ACCOUNT
NOTE: LOG ON USING SECURE PASSWORD AUTHENTICATION (SPA) CHECK BOX IN OUTLOOK,OUTLOOK EXPRESS OR WINDOW LIVE MAIL SHOULD NOT BE SELECTED.
THANKS FOR USING FIXYA.
Mar 04, 2011 | Cell Phones
Pl. send me the Hotmail settings for my Samsung Corby Gts 3653 mobile phone. outgoing and in coming server and ports all.
To setup mail client to access Windows Live Hotmail account, use the following Hotmail POP3 and SMTP configuration settings:
Incoming Server (POP3 Server): pop3.live.com
Incoming Server POP Port: 995
Incoming Server POP SSL Encryption: Yes (On or Required)
Outgoing Server (SMTP Server): smtp.live.com
Outgoing Server SMTP Port: 25
Outgoing Server Authentication: Yes (On - Use POP username and password or Hotmail credentials)
Outgoing Server TLS or SSL Secure Encrypted Connection: Yes (On or Required)
Tip : Outgoing Server of Hotmail also supports port 587, useful for people who encounters error for STMP due to ISP blockage or any other reason.
User Name: Windows Live ID (e.g. yourname@hotmail.com)
Password: password used to sign in to Hotmail or Windows Live service
Note: "Log on using Secure Password Authentication (SPA)"
Feb 16, 2011 | Computers & Internet
Sending reported error (0x800CCC80) : 'None of the authentication methods supported by this client are supported by your server.'
Is this when trying to send e-mail via outlook? Check the account settings in outlook to be sure the authentication mechanism is supported by your email provider
Apr 03, 2010 | Microsoft Office Professional 2007 Full...
Your-Freedom - OpenVPN - SMTP server with SSL
Unfortunately XP is no longer supported.
Feb 27, 2017 | Computers & Internet
Error (0x800ccc80) what does this mean?
Literally it means that Outlook tried authenticating with some authentication methods (password, encrypted password, and so on) but the server did not support any of them.
More likely, either the server did not send the list of supported methods, or something in between ate them. Check your antivirus settings, and verify that no encryption or advanced authentication is needed in the account settings.
If it still doesn't work, turn on debug recording in the Outlook advanced features and try again:
http://support.microsoft.com/kb/831053/en-us
When posting the debug log, keep in mind that it could contain sensitive information such as your email password in obfuscated format, and anyone reading the log could be able to decode it.
Oct 22, 2009 | Microsoft Outlook 2003 for PC
Sending from Office 2007
Go to Tools > Account Settings > Double click the account > More Settings > Outgoing Server > ‘Log on to incoming mail server before sending mail’.
Sep 08, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
20 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
