My heating/air conditioning unit has been blowing all day. Neither the furnace nor the air cinditioner has been turned on. What is the problem?
  • Anonymous Jun 10, 2008
    I have
  • Anonymous Aug 12, 2008
    I need how to check the thermostat
  • 165 Answers
Check fan switch on thermostat
Posted on Jun 10, 2008
No heat but blows cold air
First, amke sure your air cinditioner is on the off position, Next, check your resovoir for your anti-freeze..coolant level, last thing I can thing of is it could be your heat exchanger.
Thanks, Terry
Mar 14, 2014 | Ford Escort Cars & Trucks
I have a Coleman/Evcon furnace model #DGU08016UB that has a concern. In my attempt to check my furnace before we need it for the winter; the following condition occurred. Condition: Flashing code of...
jump out pressure switch see if it lights check hose to pressure switch see if they are split or connections are not good ,cut off ends and put back on presure switch.
Sep 21, 2011 | Coleman Heating & Cooling
What are twinned units?
Twin units can be two airconditioner condensers and/or two furnaces. Most manufacturers make a twinning kit that will wire two units together to operate simultaneously by one thermostat. At times, one may operate as a first stage of heating (cooling) and then the other unit can operate as second stage. Twinning unit are beneficial in commercial buildings where the load conditions vary constantly. For instance, if you twin two 4 ton units together. On a nice cool day, you may only need 4 tons of air conditioning. So, the thermostat will only turn on one unit. On a hotter day, you may need 8 tons of air, so the thermostat will turn on both units. In case you are thinking about doing this, the biggest mistake in twinning units together is using a common return air for the furnaces. Make sure you separate the return air cavities and ductwork for both of your furnaces If you don't have separate returns, you have the possibility of one of the blowers starting backwards. (talking form experience LOL)
Aug 13, 2011 | Heating & Cooling
Arcoaire heating/air conditioner continually cycles condensation
a possible solution is to install an air dryer in line with this tube
Jan 03, 2010 | Calvin Klein The Field Controls Company...
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
My electric furnace/heat pump runs even when the therm is off.
electric furnaces turn on the heat in stages so you dont get a major surge. the fan and the "first stage of heat" are on the same switch. that switch is stuck closed, so that it always has power going thru it. it needs to be replaced
Aug 27, 2009 | Heating & Cooling
In my mobile home I have a coleman furnace model number 7970-856. It was over 100 degrees today and my furnace fan is stuck running and I don't now if it's supposed to do day. There is no fan switch on the...
There is a fan cycle switch that turns on the fan when the unit heats up (so it won't be blowing cold air) and runs the fan after the unit has shut off to remove heat from the unit. Sounds like it bit the dust. It is located next to the firebox.
Jul 29, 2009 | Heating & Cooling
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
No heat, just cold air blowing
the problem you are having is usualy related to. #1 a high limit condition.(check the filter,then cycle the power off then on). Does the furnace have a diagnostic indicator?
Jan 04, 2009 | American Standard WCZ060F Air Conditioner
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
