I am unable to use the bluetooth app in my laptop..the moment i open, it shows error 797 a connection to the remote access server was not made because the modem was not found.......please help me..........
This is for GPRS connection
You must have from your
network provider: the internet access point name, your user name and
password.
Download and unzip the attached file in a folder on your
desktop
1- Disconnect the device from your desktop
2- On the
Activesync icon on your desktop, open "Connection Settings". Uncheck "Allow USB
Connection".
3- On your device: Go to "Beam" (in Settings/Connections), and
uncheck "Receive all Incoming beams".
4- Then in Programs, click on "Wireless
Modem". With the Connection type on USB, click on "Start".
5- Now, connect
your device to the desktop. The "Found New Hardware Wizard" starts on your
desktop. Click "Install from a specific location", then "Don't search. I will
choose...", then click on "Modems", and "Have Disk..." and go to the folder where
you unzipped the attached file.
The HTC USB Modem will be shown in the
compatible hardware: click to install. Continue if you receive the alert of the
software not passing the Windows XP compatibility test (Continue anyway).
Finish.
6- Now, in Control Panel of your desktop, open "Phone and Modem
Options". Select the "HTC USB Modem" and click on "Properties". In the
"Advanced" tab type for "Extra initialization
commands":
AT+CGDCONT=1,"IP","xxx","",0,0
where xxx is your internet
access point.
Click OK to finish.
7- On your device (always open in the
Wireless Modem program), click on Tools/Options. Check the Preset GPRS
connections and write in the APN, your network provider internet access
point.
8- Finally, on your desktop, go to "Network Connections" and click
"Create a new connection". Choose "Connect to the internet", then "Set up my
connection manually". Click "Connect using a dial-up modem", then give a name to
your ISP. In phone number type *99#. Get username and password from your network
provider.
Better keep a shortcut of this connection on your desktop for
quick access.
Each time you want to use your device as a
modem:
Disconnect your device
Disable Activesync from your desktop by
unchecking the "Allow USB connection"
Open Wireless Modem on your device and
push on Start (with the Connection Type on USB)
Connect your device, then
dial from your desktop using the shortcut you created
PS: Remember to
enable Activesync once you've finished.
