Question about Haier Heating & Cooling
I have a Haier HWF05XC6 for about a 120 sf room and it does not seem to get cool enough in the middle of the night. I checked the filter and cleaned it out last weekend so that should not be a problem. The unit itself is about a year old.
5 Suggested Answers
alex_salve
  • 78 Answers
SOURCE: My Sanyo KS1211W split air conditioning unit does not cool
u r compressor is not functioning,sure u need the service technician
Posted on May 17, 2009
  • 2976 Answers
SOURCE: my frigidaire window AC is not cooling anymore
Does it get cold? You can try cleaning the fins-both inside and outside, with windex. Smoling & cooking will create a sticky deposit that will make dist that gets through the filter stick and it won't cool properly.
If it doesn.t get cold any more, try replacing the starting capacitor. About $5. If that doesn't take care of it, just replace the unit. They are cheap enough these days, that you can replace a unit with a more energy efficient unit for the same cost or less as a repair would cost.
Posted on May 25, 2009
  • 251 Answers
SOURCE: My Haier wondow air conditioner
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
SOURCE: My Haier Commercial Cool A/C says "STOP" as an error message and won't turn on.
Bring it outside or to your tub and tip it on a 45 degree angle some water will drip out...once a puddle has come out of this thing it will work again but u will need to properly drain it eventually unless u wanna tip it and drain it every few days. But thats what ive been doing with mine...
Posted on Sep 04, 2012
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
I have a Haier Wall Air Conditioner. It's on cool
Filter may be clogged. I have one and it has a filter which I clean regularly.
Sep 11, 2012 | Heating & Cooling
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
BRAND NEW AC IS FREEZING UP
Temp set to cool. shut it down for a hour or so . close all unused rooms. set tstat to mid range and start it up again . when it cycles off and its still to warm in the room trun the stat down tell it comes on again. Also check the filter and make ceratin it is clean.
Jul 15, 2011 | Haier ESA3109 WallWindow Air Conditioner
My A/C was serviced last week and it was fine until last night when the cooling is not enough again
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 15, 2011 | LG Heating & Cooling
A/c seems not to working cooling down room What are my options?
Could be several factors. Let me start by saying the unit you have should cool a room that totals around 450 square feet (Approx.).
If you do not know your rooms square footage just multiply the width of the room x the length of the room.
(e.g. 20' x 10' = 200 SF)
The above 450 SF is for a room with typical 8' ceilings. This is also a "Rule-Of-Thumb" measurement, as windows, doors, insulation, and air leakages (heat gain) also play a role in calculation of heat loads. But this will get you close....
If the room is larger than 450 S.F. in size then the unit is too small for this size room.
A rule of tumb for sizing is: every 600 square feet requires a ton (or 12,000 BTU) of cooling. Again, without doing a proper load calculation on the room or area being cooled, it is hard to be exact.
The other possibility is the unit is not operating as it should due to mechanical or other issues. This is hard to specify. COuld be refrigerant levels are low, coils dirty, or filter dirty.
Sep 02, 2010 | Maytag Portable Air Conditioner M6P09S2A
I have a Haier ESA3085 that I set the temp to go to 73 degrees and even lower but does not go below 77 degrees, what can be causing this?
The unit could be low on refrigerant. It could have a clogged evaporator or condenser coil. It may not be big enough to carry the load of the room it is supposed to cool. Usually the biggest problem with all air conditioners is they need cleaned. I would check this first.
Jun 28, 2010 | Haier Air Conditioner
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Ac ices over
First you need to make sure the filter is clean to allow good air flow through the evaporator. If the filter is clean make sure the evaporator is not plugged up with dust and lint. If all that is ok your problem is the a/c BTU's is to big for the size room you have the a/c in and it is getting the room too cold. If that happens the evaporator will ice up and will not cool the room.
Jul 08, 2007 | Haier HWR06XC5 Wall/Window Air Conditioner
Heating & Cooling Logo
85 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
