Question about Haier hwr10xc6 Air Conditioner
Haier air conditioner # HWR06XC6
Is there a drain plug and if so where is it located........?
  • illyria_X24 Jun 27, 2008
    .. No drain.. Air conditioner has started .. spitting water back into my room, There was some ice on the front, I cleaned that all off .. .. . But it's still doing it. ;s if you have any suggestions.. email Illyria_x24@hotmail.com
  • kbeasley68 Aug 01, 2008
    I have the same problem.Water is spitting from the air conditioner. My husband has even drilled holes in it for it to drain.We still have the same problem.It stops for a few days and then you have the same problem again and again. I suggest they discontinue this one! It's ridiculous.Anyone have any suggestions on how to solve this one please email me at kbeasley68@peoplepc.com.
I have the same air conditioner and have call Haier customer support and they are also unable to tell me where the drain is. The manual says not to drill holes in the trap but I think that is the only option.
Posted on Jun 10, 2008
1998 FXDL drain plug location
Hi Anonymous, the oil pan is located underneath the transmission the engine oil drain plug is located on the bottom of the pan in the front left corner. The transmission drain plug is located on the bottom on the right center side. Good luck
Apr 29, 2014 | Harley Davidson Motorcycles
Drain oil plug torque
There may be two plugs (I doubt it) ... typically, the engine and transmission share the engine oil ... one plug.
Aug 28, 2013 | 2003 Harley Davidson FXST Softail Standard
Where is the oil plug drain located on a 2010 harley wide glide ?
The oil drain plug for your Wide Glide is located on the bottom of the transmission as the oil tank is in this location. The oil drain plug is usually located at the right front of the oil pan.
Good Luck
Steve
Jun 12, 2011 | 2010 Harley Davidson FXDWG Dyna Wide Glide
I have a Coleman Powermate PM0435001 5000W with a Subaru EX30D 10HP OHV/OHC gasoline engine. I want to change the oil and cant find a drain plug. Did I overlook it or does it not have a drain plug? If not...
You probably overlooked the drain plug, it is usually located on the mounting base of the engine. BUT, there have been some engines (old cheap ones) that the oil was drained by tipping the engine and draining out the oil fill. I am almost positive yours is not one of these.
Your manual is here, but that is only an "insert". It does look like the drain plug is located on the base of the engine. Find the spark plug, and the drain plug is almost directly underneath it at the very bottom of the engine.
More information is available from Subaru's website, including owners manual and especially a service and parts manuals. Your drain plug is item #13 on page 2 of the owners manual located here:
http://www.robinamerica.com/pmanuals.aspx?pid=80
Jun 06, 2010 | Coleman Powermate Powermate 5000W...
Drain plug radiator location
Hi!!!
Drain plug is located on radiator bottom facing engine, driver side.
Note: Never open drain plug when radiator is hot, wait for it to cool down, remove radiator cap to release pressure then open drain plug.
Don't forget to rate this answer!!
Apr 19, 2010 | 2003 GMC Envoy
Where is the radiator drain plug located on a 97 chevy 1500 Z71? I'm trying to flush the radiator,but cannot find it.
It's located on the drivers side of the radiator opposite of the lower radiator hose. Note: you may be better off disconnecting the lower radiator hose, it's common for the drain plug to break or the O-rings to split causing more work to drain the radiator. That's why most tech's will drain the radiator from the lower radiator hose, less chance of breaking the radiator drain plug and most new cars now don't come with a drain plug to the radiator.
Mar 05, 2010 | 1997 Chevrolet C3500
Primary drain plug 2002 dyna superglide location and transmission drain plug location
transmission drain plug points straight down on the right side of the bike just inside in the frame rail size socket to use is 5/8. primary drain plug is below he clutch cover on the left side of the bike it is a T40 torx bit to remove that drain plug
Oct 28, 2009 | 2004 Harley Davidson FXDWG - FXDWGI Dyna...
Location of drain plug, fill plug and correct oil level plug for 5 speed manual transmission
I don't know if there is a fill plug. I just use the level plug located on driver's side right above the inner CV joint of the half-shaft (axle) to fill it. A piece of flexible tubing connected to a funnel works well. The drain plug is fairly near the center of the bottom of the gearbox housing (behind the bell housing). The level plug has a 24mm, fairly flat, hex head, and the drain plug is a recessed plug with a 3/8" (?) square hole (for a socket handle).
Jun 02, 2009 | 1993 Geo Metro
Haier hwr10xc6 Air Conditioner Logo
983 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
