Brivis Ducted Heating system. No display on Programmable controller inside hoiuse. Electronic Control (Model 14100) located on Heater (outside house)displays "Searching". Have turned off power and left for 1 hr then turned back on - no change. Tried resetting through buttons but no change. Have assumed Electronic controller has died - but can't find troubleshooting guide to prove. Don't want to waste $$$ if can be avoided.
I have an identical issue with my Brivis.
Did you get a solution?
Mine can be running, then goes blank and says searching. it will eventually come back.
Just wondering if you had to replace the 14100?
Cheers
James
Posted on Jun 01, 2010
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
May 31, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Honetweel heater control unit failing
you would have to study the wirring diagram etc but any gas heater control should work, you just have to know how to hook it up as the ignition etc is all incorporated in the control
May 03, 2009 | Honeywell Programmable Thermostat Heater
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
790 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
