Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Hot surface light - element that has failed
Is there a way to determine which element has failed? Or do I need to contact someone to fix the element that has failed?
  • 413 Answers
The element can't be fixed, only replaced. There is a way to determine which element has failed..
It will involve lifting the cooktop and removing a specific wire off each element, one at a time, until the light extinguishes....
Posted on Jun 10, 2008
The grill and oven is not heating up
1.a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Mar 31, 2015 | Ovens
Smeg suk 61 mx8 oven is not working, just the cooling fan runs and all the digital lights , the timer are off.
THINGS TO CHECK:
the broil element
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Mar 29, 2015 | Smeg Ovens
I have a tricity benfix electric oven.. My main oven and top oven have both stopped working, but my hob and grill work fine, how do I fix my ovens? What the problem?
1.Even a bad relay door switch will hinder your oven from operating.
THINGS TO CHECK:
the broil element
The bake element
Mar 20, 2015 | Ovens
Err 5 on Smeg Electric built in oven. SCP112SG8 . Oven will not switch on but has power to the clock and light inside. Seems to be no easy Help from Smeg to retrieve these error codes. Please could...
THINGS TO CHECK:
the broil element
The bake element
Mar 16, 2015 | Smeg Ovens
My oven will not get hot
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
THINGS TO CHECK:
the broil element
The bake element
Jun 18, 2014 | Frigidaire Ovens
1998 Whirlpool single oven won't get hot, why?
1.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
2.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
3.
4.Even a bad relay door switch will hinder your oven from operating.
THINGS TO CHECK:
the broil element
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
I offer free advice bcuz God is so good!
May 01, 2014 | Whirlpool RBS275PD Electric Single Oven
Oven doesn't get hot grill does get hot
THINGS TO CHECK:
the broil element
The bake element
Jan 14, 2014 | Belling Ovens
Belling classic 900e grill & hotplates not working
THINGS TO CHECK:
the broil element
The bake element
Dec 13, 2013 | Belling Ovens
The hot surface light is staying on and will not go off. Is there a way to fix this?
Each element contains a sensor to detect when the element is hot, this sensor has failed. The element will have to be replaced. If there is only one light to indicate hot surface, you will have to determine which element has failed.
Jun 09, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
The right front burner won't heat
The switch probably failed. Remove power. Take off the top rear cover and inspect the switch for signs of discoloration (burned or brown areas). If looks OK then maybe the element failed.
May 28, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
80 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
