Question about Kenwood KDC-MP2035 CD Player
Mp2035 cd player will not turn on.
I have the Kenwood mp2035 stereo in my boat and when I installed an amp I accidently cut all three power wires. I have connected all three wires the same as they were but the stereo will not turn on at all. What can I do to fix this problem?
  • Anonymous Mar 03, 2009
    i have the same problem but my eject button still works
    Novelist:
  • 100 Answers
My hunch is that the fuses blew. When you cut all three at once you shorted the battery to ground and most likely blew out the fuses. Check the fuses and let me know. That is my best guess. Good luck
-Andrew Hawkins
Posted on Jun 12, 2008
Kenwood kdc-152 protext mode
Disconnect the power, check your speaker wire connections behind the stereo and at the speakers. Reconnect the power and test.
Aug 19, 2012 | Kenwood KDC-MP2035 CD Player
Hooking up a kenwood mp235
Blue/White - Power Control/Motor Antenna Control Wire
Brown - TEL Mute Wire
Blue - ANT. Cont. (Not Used)
White/Black - Front Left Speaker -
White - Front Left Speaker +
Gray/Black - Front Right Speaker -
Gray - Front Right Speaker +
Green/Black - Rear Left Speaker -
Green - Rear Left Speaker +
Purple/Black - Rear Right Speaker -
Purple - Rear Right Speaker +
Red - Ignition Wire (Switched +)
Yellow - Battery Wire (Continuous +)
Black - Ground Wire -
Here is a copy of the User Manual:
http://www.masterspas.com/manuals_av/Kenwood_KDC-MP2035.pdf
Jul 22, 2010 | Kenwood KDC-MP235 CD Player
I need unlock code for my kdc-mp2035 kenwood stereo
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Mar 27, 2010 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-MP2035 cd player has power and everything functions but there is no sound. The 10A fuse in the unit is good.
make sure that the power output is enabled. this will turn on you internal amp. I have the same unit and I fouund this to be a problem. If this does not work your out put amps might be fried. good luck.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 07, 2009 | Kenwood KDC-MP2035 CD Player
Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
HELP STEREO CUTS OUT!
ok , ive found the problem with mine. I checked the voltage between the earth wire on the head unit and the battery in the car. I found that when i turned the headunit up to around 17-20 there was up to 3volts differance, which is when it would cut out. So ive run a new earth wire and she's all sweet . Even the cd player works now.
Aug 11, 2008 | JVC AM FM CD DET FACE CAR STEREO
Not Holding the Memory
Sounds like a wiring problem.
There is a YELLOW wire that should be connected to a constant +12 volt supply when the vehicle is off. This retains the settings.
Check the connections and see if thats the problem.
Please RATE my solution at the bottom.
Best of Luck.
Nov 19, 2007 | Kenwood KDC-MP2035 CD Player
I had this same exact problem when my last older Kenwood Marine stereo cooked itself while I had it up loud for a few weekends on the lake. (smelled like it had burned inside). I went out and bought a new Kenwood KMR-550u stereo deck. (I do not have an additional amp). I hooked it up to the exact connections where my older Kenwood stereo unit had been hooked up, as I never had a problem with this for the past three years until it failed after smelling of burning elelectrical. I had chalked the problem up to heavy rain we had one day. Every time I turned up the volume, sometimes up to 27 out of 35 possible, or 29, or 32, the stereo would suddenly shut off as if I had turned it off. After a few seconds the stereo would come back on, but unless I was quick enough to turn down the volume it would do it again right away. Of course on a boat, we were beached in a cove and the engine was not running when I encountered this. I searched the internet finding hundreds of similar complaints and several dozen theories of all types, but only a couple that pointed me towards the power (voltage) idea as the problem. I put a volt meter on the positive & negative wires powering the stereo. I watched as I gradually turned up the volume, the voltage on the power wire gradually decreased from 12.5 volts, down into the 11 range, and as it hit 10.9 or 10.8 volts it shut off typically around a volume of 32. The red power wire in my boat that never seemed to have an issue with my old stereo until it fried was determined to actually be inadequate for the power flow for the new Kenwood, and probably was the culprit of my failed older unit. I offer this sound advice: Run a new pair of positive & negative wires directly from the battery (with an appropriate fuse of course (the deck has a 10 amp fuse in it's back so I would use that at the battery) to the stereo. Check the voltage as you turn the volume up into the high 20's and low 30's to ensure you are still getting voltage in the mid to high 11-12 volt range. The stereo is designed to require a minimum of 10.8 volts to operate, and when it drops below that it protects itself and shuts down.
Mar 24, 2007 | Kenwood Sirius KDC-MP522 CD Player
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
Kenwood KDC-MP2035 CD Player Logo
149 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
