Cisco 1721 Router Logo
Posted on Oct 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i boot up my router the output is all mixed up characters
Jonathan Shreve
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 143 Answers
  • Posted on Oct 28, 2010
Jonathan Shreve
Expert
Level 2:
Mentor:
Answers
143
Questions
0
Helped
43436
Points
470
I recently had a similar issue with a wrt54g Linksys (by Cisco) router. It happened when I used Internet Explorer 7 or 8. When I used Firefox, there was no issue. So, I suggest using a different web browser.
Error code 051310
Here is the info that may help you...
Error Code: 051310
Our experience has shown that this error message is typically caused by WEP Key issues. Please read the following information:
* Check Nintendo's router info for special notes, if available, for your router.
1. Click here to go to our Wireless Router Configuration page.
2. Use the drop-down box on the left to select, if available, your router manufacturer.
3. Click on your router's model number, if available.
4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
* Are you using WEP security on your router?
1. Log into the router using the default IP (consult your router's manual for assistance)
2. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
3. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
4. The WEP Key must be a Hexadecimal (1-9, A-F, no other special characters or letters).
5. Verify they are using the WEP Key in the first (#1) slot. Even though their router may have multiple slots, the Nintendo DS is only compatible with the WEP Key in slot #1.
* Check to see if your router is using MAC filtering.
1. Log into the router using the default IP.
2. Find the section for MAC Filtering (typically under "Security").
3. If MAC Filtering is on ("enabled"), enter the Nintendo DS?s MAC address to the list of approved MAC address. For info on locating the DS?s MAC address, click here.
For instructions on how to find the MAC address for Nintendo DSi, click here.
(For assistance with locating the MAC Filtering section of your router's setup tool, please consult the router's manual or contact the manufacturer.)
* Nintendo DS / DS Lite only:Check to see if your router is set to "g only" mode. In order to work with the Nintendo DS, the router must be set to "mixed" or "b and g".
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
1helpful
I need to know which power adapter to use in connecting my Belkin Wireless Pre-N router Part # F5D8230-4. Somehow my son mixed the adapter in with a box of others that were ready to be recycled. Is there...
look on the router on the bottom or at the power jack. The voltage and amperage level will be there. Then match it to the power supply that fits and has the same voltage/amp output.
We have an error code 51310 for wifi! Can you
Error Code: 51310 Our experience has shown that this error message is typically caused by WEP Key issues. Please read the following information:
  • Check Nintendo's router info for special notes, if available, for your router.
  • Are you using WEP security on your router?
    3. The WEP key is case sensitive, so be sure to enter it exactly as it appears.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (1-9, A-F, no other special characters or letters).
    6. Verify they are using the WEP Key in the first (#1) slot. Even though your router may have multiple slots, the Nintendo DS is only compatible with the WEP Key in slot #1.
  • Check to see if your router is using MAC filtering.
    3. If MAC Filtering is on ("enabled"), enter the Nintendo DS’s MAC address to the list of approved MAC address. For info on locating the DS’s MAC address, click here. For instructions on how to find the MAC address for Nintendo DSi or Nintendo DSi XL, click here.
  • When using connection files 1,2, or 3 on any Nintendo DS system:Check to see if your router is set to "g only" mode. In order to work with the Nintendo DS, the router must be set to "mixed" or "b and g".
Connection error code 51301
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);This error is caused by issues with the WEP Key of your wirless network.
To solve this error :
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
If your router is using WEP encryption
  • * Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • * 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • * 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
If your router is using MAC filtering, ensure the DS MAC address has been added to the list of approved MAC address on your wireless router settings
Set your router settings to "mixed" or "b and g" mode when using connection files 1,2, or 3 .
1helpful
I have a di-524 router and my dsi tries to connect using wep and I get the error message error code: 051300-1 can you help
Error Code: 051300 Our experience has shown that this error message is typically caused by WEP Key issues. Please read the following information:
Ipod touch won't connect to my wifi
things to check again:
1- if DHCP enabled 2- which type of security encryption is used, if WEP change to WPA, use numbers instead of mixed characters for wifi password 3- if MAC filtering is on on the router 4- if signal strength is good
hope that any one of the above solves your problem
Cisco 2600 series router problem
are you clicking on the reset defaults button when you set up hypertrm? while it's booting it will run a boot test. if you can see any of it, see if it passes. Try another computer?
Error Code 51331
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
2helpful
Error code:51331
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
