Question about Visonik V810D2 Car Subwoofer
What air space is needed for the v810d2 sub plus what size of air ports
Yes i got a 1998 s 10 ex cab. and i you like to put four 12" subs in it. and i would like it to be ported. and all the sud faceinf up, and port too. will that work for me.
Posted on Aug 08, 2008
  • 70 Answers
If its the box it only needs like a 1 to 2 inch hole. i have 4 tens in my car and alls i have is a single 1 inch hole. if this isnt what your talking about try and email me back.
Posted on Jun 12, 2008
What would be the ported enclosure airspace requirement for a dynex 10" sub?
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 11 inches x 11 inches x 11 inches. Hope this helps
Feb 25, 2011 | Dynex 10" Single-Voice-Coil 4-Ohm...
How much airspace do i need for my subwoofer and should i port the box
Jun 26, 2010 | DB Drive SP10.1 Car Subwoofer
Need to know airspace required for this sub
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. Box size will be 13 inches x 13 inches x 13 inches
Jun 19, 2010 | Lanzar MAX12D Car Subwoofer
Is it better to have your sub box ported or sealed
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches. 15 inch, the box will be 16 x 16 x 16
Jun 12, 2010 | Car Audio & Video
What type and size of box should i use with this
May 26, 2010 | Phoenix Digital PD-131 Car Subwoofer
What size enclosure is recommended for 2 10" kenwood tornado subs?
If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 11 inches x 11 inches x 11 inches
Apr 19, 2010 | Kenwood 2 10 " SUBS SUBWOOFERS 500W POWER...
How much air space do boss blade 15 need
Subwoofers differ in only one way. You get an "Open Air" and a "Closed air" subwoofer, That being said, you'll have to check on your magnet which one you have to make the boxes for that sub. If it is an "Open air" Subwoofer, you should see a "wire mesh" or "grid" in the centre, at the back of the magnet. If it is a "Closed air", the magnet will be solid with no hole whatsoever.
If it is a "Open air" sub, your boxes should be sealed with silicone, and no ports are to be cut in your box.
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 250mm, depending on the frequency of bass you require.
On a 15 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Nov 24, 2009 | Boss Blade BL240DVC Subwoofer - 15" Dual 4...
Need dimensions for 12' 450watt IMPP Subwoolfers for proper air space
With "Closed air" subs, you should have 2 ports below your sub and the port sizes should be around 50mm in diameter. You should start with a 100mm long piece in the one box and add 50mm increments to "tune" the port up to 200mm, depending on the frequency of bass you require.
On a 12 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 27 liters, meaning that you will end up with a box of 16 inches high, x 16 inches wide, x 16 inches deep. Or 320mm high, x 320mm wide, x 320mm deep.
Enjoy!
Oct 14, 2009 | Car Audio & Video
Size of boxes
Wow you are in luck, I used to be an Audiobahn dealer. Designing sub enclosures is my fulltime job. So here you go.-
If you are looking for sound that is very smooth, and has a very low end shaking everything setting off car alarms. You will need a PORTED BOX that is 3 CUBIC FEET FOR EACH SUB WOOFER. It actually calls for 2.7cu.ft but after you add speaker displacement and bracing it should be at least 3 cu.ft. The port can be either round or square made of plastic or 3/4" wood respectively. My port suggestions are dependent on how much space you have. The shortest round port might make some noise (too much pressure!). So think about that first. Anyway the short port is 3" diameter and 15.5" long. The longer port is 4" in diameter and 28.25" long. The rectangular wood port can also be either (port measurements are inside diamensions) 3" w x 3" w x 18.5" long (short port) or 2 w x 10.5 h x 48' long. The second longer wood port is recommended most but will take up a lot of space. The fact that you have to subtract the port volume from the box makes for space issues in cars. Also the second wood port sounds better and won't make much wind noise, but takes up .75 cu.ft worth of space. So in plain english your box will have to have an internal volume of 3.75cu.ft. An example of this could be made of 3/4" thick MDF, have 1" x 1" internal bracing and measure (box dimensions are external and assumes the use of 3/4" MDF) 12" h x 18" w x 30" deep. The port is an integral part of the box fitting inside. I'm sorry I can't provide any drawings to make things easier. Now this box size is one that I ran through a computer program I use. So it is not the same as the manufactures recommendations. I will list those as well.
The second box is an example using a round short port and also uses 3/4" MDF, 1 x 1" bracing, the 3" dia x 15.5" long port, and measures 12" x 18" x 24" externally.
If space is an issue try checking out the information below. -I got it from Audiobahn-
If for some reason it doesn't show up or you need assistance let me know. Good luck and enjoy your new setup-I'm sure you'll be happily disturbing the peace soon!
-Dynami
Model # AW1006T
Ported
Air Space (Cu. Ft.) 0.65
Port Size (Inches) 2 x 6.5
Port Vel. (%) 48.31
-3dB (Hz) 31.5
Tune Freq. (Hz) 40
Sub Disp. (Cu. Ft.) 0.21
Port Disp.(Cu. Ft.) 0.01
Total Vol. (Cu. Ft.) 0.75
Ported
Air Space (Cu. Ft.) 1.4
Port Size (Inches) 3 x 6.75
Port Vel. (%) 24.19
-3dB (Hz) 30
Tune Freq. (Hz) 39
Port Disp.(Cu. Ft.) 0.024
Total Vol. (Cu. Ft.) 1.5
Ported
Air Space (Cu. Ft.) 2.4
Port Size (Inches) 4 x 6.25
Port Vel. (%) 14.39
-3dB (Hz) 29
Tune Freq. (Hz) 39
Port Disp.(Cu. Ft.) 0.04
Total Vol. (Cu. Ft.) 2.5
EBP 74 80 80
Sealed NR NR NR
Minimum (Cu. Ft.) 0.5
Maximum (Cu. Ft.) 1
SPL (dB) 80
All sealed boxes already include the displacment for the subwoofer. NR = (Not Recommended)
Mar 08, 2009 | AudioBahn AW1006T Car Subwoofer
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Visonik V810D2 Car Subwoofer Logo
115 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
ELECTRICKS
ELECTRICKS
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
