Hi!, If your computer is slow then please do these tasks. 1) Run Disk Cleanup from system tools 2) Disable Screen Saver. 3) Run De-fragmentation from system tools
Have you checked the battery in the cabinet? Try to remove it and then start your system. If this does not helps, ensure that you remove all the connections, i.e. your power connections with your hard drive, remove the ram and then plug everything back in. This may happen due to a loose connection and because of which the system is not getting enough resource to boot.
You need to got START, then CONTROL PANEL then USER ACCOUNTS and remove the password under the person you are login in as. You might have to log in as ADMINISTRATOR to edit the USER ACCOUNT settings.
You should see the speaker sockets behind your computer. They will be usually marked audio out, audio in and microphone. If you have a 4.1 or higher sound card, then you may have upto 5 or more sockets. Simply plug in the speakers according to the colour.
Ok, there should be a cable with which you connect your iPod, iTunes should recognize it and you should be able to transfer music.
Otherwise try going My Computer, find your iPod folder , open it, open your desired folder and drag songs from the folder that your iTunes music is in into you iPod folder
i cant start the screen
