Question about Bose Wave Radio
BOOM BOOM BOOM
Too much bass sound. When volume is very low bass is boom, boom, radio does not sound as loud and clear as it did when new. When volume is turned up bass is BOOM BOOM BOOM sounds awful. Is there help or any ideas what may be wrong. I have 2 Bose CD Radios and they both sound about the same. Thanks
    Scholar:
  • 102 Answers
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Posted on Jan 02, 2010
How to fix loud sounds from my subwwofers
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What loud sounds? Feedback, or bass boom?
Jul 13, 2014 | Audio Players & Recorders
The pickup on my epiphone pr5 booms if i play loud, and if i tap the body anywhere it scratches and booms even with new battery
Sounds like you are using incorrect settings on the amp you are using. Try all tone controls at 12 o'clock as a start. Excess bass boost is a good way to have the problem occur. Also back off the volume control. "Handling" noise or scratching from handling the guitar is NORMAL for this type pickup. Back down the volume and DO NOT boost the highs or lows to help with the handling noise problem.
May 23, 2011 | Epiphone PR5-E Electro Acoustic Guitar...
When the truck is turned on the speakers make a boom sound then they buzz??
is this afetermarket stereo if so check you ground on the amps
Feb 09, 2011 | Car Audio & Video
Remote bass control short
It Could be Eiher Problem Make Sure The Remote our using is thew same brand as the amp its plugged in to
May 27, 2009 | AudioBahn A4002T Car Audio Amplifier
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
Whenever i wire 2 4 ohm svc subs the system just starts to pound real hard and its not like bass moving to music but just bass just moving up and down
It sounds like you have an open shield ground. To check the shield in your head unit, read through the following page.
Temporary Shield Ground Repair
Aug 26, 2008 | Profile 600MSX Car Audio Amplifier
Need to find a satellite receiver for my JVC-200 boom box
I have a JVC boom box and I use a Sirius Sratus radio on mine through the line input of the boom box. Probably sounds better than the Sirius boom box that plugs into it.
Aug 25, 2008 | Audio Players & Recorders
My car amp is not working right.....
  • Remove the RCA preout connections from the amp. If the problem is still there, we know it's the amp, not the head unit.
  • Check your gain settings. Set them to 50% and see if that affects the issue at all.
  • Check that your ground wire is nice and short.
  • If the issue is still there, it's possible it's internal to the amp and will need repair.
Mar 19, 2008 | Car Audio & Video
Systems shuts off if sound gets too loud.
Yes, i had this same problem. If it was too loud, at level 37+, any loud boom would shut down the subwoofer, subsequently shutting down the speakers. As such, I figured it might have been the 8 pin dim cable, but that wasn't it. What solved the problem was lowerin the BASS level. Not the level on the subwoofer, but the actual BASS level. I had it at +10 (the max) and it was too much for the system to handle. I don't think I ever had it like that so I'm assuming someone, maybe my daughters, moved the settings. But anyway, moving the bass level back down to either 0 or +3 at most maintains the "boom" effect of the subwoofer minus the shutting off of the system.
Oct 20, 2006 | JVC TH-C60 System
Bose Wave Radio Logo
987 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
