Question about Autotek MX3000.1 Car Audio Amplifier
Autotek 7100 BTS series
I have an Autotek 7100 amp, BTS series. This is an older amp that works just fine except the "treble" gain potentiometer broke off. Can anyone help me with where I can get a replacement. The only identifying part number is
"B20K x2"
  • 351wMUSTANG Jun 10, 2008
    I have an Autotek 7100 amp, BTS series. This is an older amp that works just fine except the "treble" gain potentiometer broke off. Can anyone help with where I can get a replacement. The only identifying part number is: "B20K x2"
  • Anonymous Mar 25, 2014
    amp goes straight to protection when powered
    Scholar:
  • 71 Answers
99% of pots are off the shelf items.
See a tech with a parts catalog and a soldering iron.
Labor will far out price, the part.
Experience ain't cheap.
Regards, Sumthin
Posted on Jun 11, 2008
Boss ME-70 distortion changing mid play why.
Is distortion changes like we turn the OD/DS selector (changes to Boost-Natural-OD1-Blues etc)?
If so, the OD/DS potentiometer need to replace.24346541-2ss5ycyvkoajtv035dpuezke-4-0.jpg
If the changes are like increasing/decreasing GAIN/BASS/MID/TREBLE/LEVEL and also TYPE of pre-amp, then one of PREAMP potentiometer is bad.24346541-2ss5ycyvkoajtv035dpuezke-4-1.jpg
May 06, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
Peavey amp gain controll
Sounds like a bad volume potentiometer.
Apr 02, 2014 | Peavey Audio Players & Recorders
How to replace a potentiometer
Disconnect from the mains.
Unscrew the four screws in the top
Slide out the chassis
Remove the knobs
Unscrew the pot nuts
Unclip/unscrew the PCB
Unsolder the pot
Solder in new one.
Re-assemble in reverse order
Strongly suggest you youse a better quality pot
Also the treble pot tends to go on these, replace at same time
All the best, Chris
Apr 14, 2013 | Marshall MG15DFX 15 Watt Compact 2...
This bass squels if you have a bass head and cabinet. i had a 100W amp and it played fine then upgraded to a head/cab. tryed playing it with loud volume, squels. anyway to fix this?
Turn down the treble gain and mid gain... you don't need it for a bass. Prevent the guitar from "hearing" the output of the amp directly. The guitar strings make a good microphone.
Feb 27, 2011 | Epiphone EBO Electric Bass Guitar...
I got an autotek bts 7150 which is the positive and negetive speaker wires?
for stereo
speaker #1 (white = pos ,green = neg.)
speaker #2 (yellow =pos. ,blue = neg.)
for mono
white = pos., blue = neg.
Feb 22, 2011 | Autotek Car Audio & Video
There is a repetative clicking sound whenever I use the treble on my guitar. what is causing this?
Did you mean the treble control potentiometer (knob)?
This was posted as an amplifier problem, but since you mentioned that the use of the treble (button?) on the guitar is causing the clicking, i would have the treble potentiometer checked first.
It could have a loosely soldered or broken wire on any of the tabs, oxydized slider contacts, bad ground (negative) connnection, possibly dirt or damage on the resistive track inside the pot.
A broken wire can easily be resoldered, but if there is internal damage or oxydation, the potentiometer should be either cleaned or replaced.
In short words - it may be a faulty treble pot.
There are ways to disassemble and clean a potentiometer, but the difficulty of this task may vary and depends mostly on the type and build of the pot.
The other alternative is to have it replaced.
regards
Triarcuate
Sep 26, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Constant load noise when i switch my amp on
IT SOUNDS LIKE SOME COMPONENTS OR "PARTS" IN YOUR AMP ARE NOT CONNECTED TO THE CIRCUIT BOARD.
WHEN THESE AMPS ARE MANUFACTURED, SOMETIMES NOT ENOGH SOLDER IS PUT ON THE JOINTS.VIBRATIONS AND HANDLING THE AMP ROUGHLY MAY LOOSEN THESE JOINTS.
WARNING: DISCONNECT THE AMP FROM THE AC ( WALL.)
OPEN UP THE AMP.... CAREFULLY
CAUTION :DO NOT BEND THE "LEGS" OF THE LM 1875 TRANSISTOR THEY BREAK EASILY.
PUT THE SCREWS,NUTS AND WASHERS IN A BAGGIE.
LOOK CLOSELY AT THE SOLDER JOINTS.
ESPECIALLY WHERE THE POTENTIOMETERS ARE SOLDERED TO THE CIRCUIT BOARD.
THERE ARE THREE SOLDER JOINTS ON EACH POTENTIOMETER.
WITH YOUR SOLDERING IRON.. FLOW SOME HOT SOLDER ONTO THESE JOINTS.
START WITH THE GAIN 1 ..GAIN 2..TREBLE ETC.
THIS MAY SOLVE THE PROBLEM.
IF NOT,,,, YOU MAY HAVE A BROKEN POTENTIOMETER.
OR ... A BLOWN TRANSISTOR... LM 1875 IT IS THE ONE MOUNTED TO THE HEAT SINK.
ARITHEBASSPLAYER
Mar 25, 2009 | Marshall 15 Watt Guitar Amp
Blown subs
HOW do you have it wired and what is the ohms rated on the subs
and is this amp bridgeable and at what ohms is it stable at
Do you have it Bridge to the subs to lower the ohms( Series or in Parallel)
Is the amp running hotter the normal and do you have it in a well ventilated are of your car/truck
Most car audio or at 4ohms and also is the subs dual
Aug 28, 2008 | Autotek SX280 Car Audio Amplifier
Amp volume problem
Sounds like you have a bad or dirty gain potentiometer. Try turning the gain up and down with the volume at a moderate level. If u hear static, it is possible the potentiometer is bad or dirty. Replace with one of the same value and see if that solves your problem.
Jul 15, 2008 | Rockwood Car Audio & Video
Autotek MX3000.1 Car Audio Amplifier Logo
778 people viewed this question
Top Autotek Car Audio & Video Experts
Professor_V
Professor_V
jeffrey richard
kli99gunrunn
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
