Window xp home edition install
I need to find VIAAGP1 on VIA AGP FILTER disk to finish my install.
  • 165 Answers
Search the web for the Via 4in1 driver
Posted on Jun 10, 2008
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
Yes expert ntldr missing
It means that your computer is missing a file that windows xp needs to run boot properly or is missing a program that your home edition xp needs. Repairing the OS or windows xp home edition by means of your xp instalation cd will do the job. Just insert your xp installation disk to your cd/dvd rom and select install windows xp home edition. Then select ( repair ), and so on let it finish repairing . Once your system rebooted, let it run without pressing enter or space bar. Just watch and let your computer do the job. This will probably solve your boot problem. But before doing all of this, please check your IDE or SATA cable and also the power cable that is connected to your hard drive. Try to unplug and plug again to ensure a good connection. If this won't work, you can proceed repairing Your windows xp installation or reinstalling a new xp operating system. Have a nice day and i hope i was in any help to you friend.
Aug 18, 2011 | Microsoft Windows XP Home Edition
My computer crashed and i need to install windows xp home edition but don;t have the disc what can i do
You should have a system recovery disk. If you don't, then you will need a XP Home disk. As long as you have the XP installation code (usually placed on a sticker on the outside of your comptuer), you can use any XP Home disk. It's the product code that is really needed. Go borrow a CD from a friend and use your software code that is on your computer.
Mar 13, 2011 | Microsoft Windows XP Home Edition
I want to change my windows xp to Home edition
You can also do a clean installation by following the procedure as listed below:To perform a clean installation of Windows XP, follow these steps:Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.At the Welcome to Setup screen, press ENTER to start Windows XP Setup.Read the Microsoft Software License Terms, and then press F8.Follow the instructions on the screen to select and format a partition where you want to install Windows XP.Follow the instructions on the screen to complete the Windows XP Setup.
Oct 27, 2010 | Microsoft Windows XP Professional
I had a orginal windows xp home with product key but i had installed xp professional pirted edition can i convert it into xp home orginal?
No sir you can just convert your windows into xp home original.you will have to format the pirated windows which you have then re-install your new xp home into it
use your xp home cd to format your hard disk by booting your system with the xp cd and then install your windows
Feel free to ask anything
Thanks
Aug 05, 2010 | Microsoft Windows XP Home Edition
I uninstalled my video card, it was a VIA Chrome9 ...
go to windows update in the start>all programs>windows update and click on custom. After it finishes searching for any latest updates, on the left tab, click on "Hardware, Optional" and check whatever needs updating/you need.
Hope this helps
May 20, 2010 | Microsoft Windows XP Home Edition
Ati2dvag infinite loop
mmm... try this steps.. maybe it could help.
Right click-mouse over My Computer
Properties
Hardware(Tab)
Device Manager(button)
Click [+] next to System devices
right-mouse on CPU to AGP Controller (or whatever your controller is called, mine was SiS AGP)
Update Driver(button)
Select Install from a list or specific location (Advanced)
Next(button)
Select Don't search. I will choose the driver to install.
Next(button)
Select PCI standard PCI-to-PCI bridge
Next(button)
Finish(button)
Reboot.
Mar 05, 2010 | Microsoft Windows XP Home Edition
Windows xp home edition reinstall
If you use his disk, that will be better, because if it is original HP disk, it should install all original drivers at all, however this may delete all files on the computer depending on the type of installation you do.
Installing an older version of XP home does not make a big difference , as windows will update the system using automatic updates. What must be done, is ensuring that all proper drivers are installed.
Check device manager, in control panel/system, and see if all devices are installed with proper drivers.
Oct 26, 2008 | Computers & Internet
Cannot complete installation of windows xp home edition
Have you added or changed your computer's hardware since you purchased your computer? Your Dell reinstallation disk will probably only work for the original configuration of your machine. If this is the case, dust off your old parts, remove your newer parts, then reinstall your old ones to get your system back to its original configuration. Once there, try the reinstallation again.
If this does not apply to you (or you can't get it to work), you can always purchase the operating system new (from newegg, tigerdirect or similar) and install from a disk that will have all of the drivers you need. OEM versions are cheapest, but you are on your own for support in the event of a problem. I hope this helps.
May 31, 2008 | Dell Microsoft Windows XP Home Edition
Computers & Internet Logo
David Payne
David Payne
