Question about Sony KP-51HW40 51" Rear Projection Television
Sony Big Screen Tv
The tv picture blinks off and on stops for a while then blinks again
  • Anonymous Jul 03, 2008
    tv picture blinks on then off while the timer button on the front blinks as well.
    Sergeant:
    Champion:
  • 250 Answers
Your flyback transformer is probably bad. It will need to be replaced. You could also try adjusting the voltages to the crts from the flyback. There is a set of 6 screw like pot knobs just behind the speaker grill. The bottom three knobs are the ones you want to adjust. Do it very very slowly as it shouldn't take much to correct the problem.
Posted on Jul 07, 2008
I have a old 52 inch sony tv turns on but picture blinks off and on whats wrong
A lot of their older sets (both regular TV sets and big rear projection set had this issue).
In either case it may mean with age the MASTER SCREEN control/s need to be adjusted slightly up---if too dim a picture it will blink.
A model number would tell me what to try.
Models beginning with KP are large projection and ones with KV are regular sets.
Mar 31, 2012 | Televison & Video
I have " Sony FD Trinitron WEGA KV-36HS420 36" TV
U have a soldering iron,desoldering pump or a roll of desoldering braids,a roll of solders?Can u do basic soldering and uderstand basic electronic?FBT- the flyback transformer,the big black block of a plastic with a red wire with a cap hook to a CRT-tv picture tube.Near the big block of a plastic with a red wire with a cap hook to a CRT picture tube.Inside to the right of the FBT,there are 2 power supply ICS,those 2 ICS are dead.Replaced these 2 power supply ICS near the FBT,will solved this tv LED power light indication blinking and will have stable tv power again,and tv will work.
Nov 29, 2010 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
Picture gets bright then blinks black, adjusts and then gets bright and blinks again every 4 seconds. used to be every couple of minutes.
Take the tv aparts.Caution high voltage ERA FBT.The FBT the flyback transformer.That the big block of plastic,with a red wire with a cap hook to the CRT(Tv tube).On FBT that big block of plastic there are 2 knobs one said FOCUS the other said SCREEN.Turn knob said sceen down a bit,will stop get very bright pictures and shutdown,the screen will hold high voltages.
Oct 06, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Our big screen sony tv stopped working yesterday. The power on light is blinking red intermittently and when you push it, it doesn't turn on-no sound or picture. It will stop blinking red periodically, but...
Please try disconnecting all the cables from the TV including the power cables then reconnect them back after a few minutes. You may also try connecting the power cord from the TV directly to a functional wall outlet. If the issue persists then service will be required.
Aug 27, 2009 | Sony Televison & Video
Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
Dec 06, 2008 | Sony KP-57WV600 57" Rear Projection...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
56 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
