Question about LG WD-3243RHD Front Load Washer / Dryer
Door does not open
I got this machine form a friend who moved out of his apartment but i have plugged the machine in put the door does not open can someone give me some advice on how to fix this problem.
    President:
  • 1,294 Answers
Try: Hold down "end of cycle" till the door light goes off.
or Hold down "start" & "pause" button together till light goes off. Caution, after light goes off, wait for 2 or 3 minutes before trying the door, do not force door.
Pl post back result..........
Posted on Jun 10, 2008
LG front loader washer model #wcvh6260fgg, we replaced the door boot seal, put it all together and now it won't run! It does light up and the laundry big dial select button works, my cycle and/favorites...
I had the same problem with my whirlpool and when I took it apart a wire had come out of the connector took it apart and put wire back in. problem solved. look for any loose wires also if u unplugged any connectors make sure u plug them back in where they were
Apr 04, 2014 | Washing Machines
Door boot seal
have you accidentally dislodged the wires on the door switch it maybe that, if the door does not register as being closed the machine will not start, hope this helps
Aug 04, 2017 | Washing Machines
Can't open door of ASKO W6883
If nothing else works, the washer door can be opened as follows:
This must only be done in an emergency
if the machine's glass door does not open automatically when the program has finished.
First check that there is no water left in the machine. If there is water left in the machine and it is not possible to run the Drain program, empty the machine by using the drain hose.
Make sure that the main power switch is off and that the plug has been re- moved from the wall socket.
You will find the emergency opener for the glass door in the double sealed bag.
Open the glass door by putting the opener in the slot to the right of the lock on the door. Push the opener up or down and the door will open.
Feb 28, 2011 | Asko W6021 Front Load Washer
Our front load washer had standing water in the bottom of the barrel. The repair man over the phone said it sounded like the drain was clogged. He initially couldnt find a clog anywhere and had to take...
The washtub suspension allows it to move but when overloaded it will move rather more than it is designed for and could open a gap between the washtub and the door large enough to allow items to slip through.
The suspension is carefully designed to absorb the out of balance forces, with which the washer would be noisy and tend to "walk" around the kitchen. These days consumers demand smoother and quieter performance from their washers and so it is increasingly important not to overload them.
A friend called out the service engineer to his new washer that he had been operating just like his old one. The engineer began by plugging in a laptop and looking accusingly at him said he had overloaded his new machine nine times in the few weeks since it was delivered. Guessing is no longer an acceptable method of loading the washing machine...
Mar 23, 2017 | Frigidaire ATF6000ES Front Load Washer
My old front load whirlpool isn't draining. Someone suggested opening a plug on the bottom left of the machine front that may have gotten clogged but we were unable to open it. any suggestions?
hello,
the solution giving to you i also a way of draining the water from the washer ,
But i will like to draw back your attention back to the drain pipe inside the drum of the washer..... what you need to do to fix up (solve)the problem of the drainage from here is that you have to bale out the waste water in the drum of the washer to see the cloth or dirty that have form up to block the pipe of the water out flow, remove any form of dirty around the pipe that have stop the water flowing as is expected to, with this the problem of blockage is solve.
please note this important information PUT OFF ALL FORMS OF POWER SUPPLY CONNECTED TO THE WASHER.
Thank you and thanks for using fixya.
Jun 15, 2010 | Washing Machines
Dear Sirs, I just moved into my new apartment
You need to get the correct model number. What you give is a part number. The model number you want is on the end of the motor unit nearest the door. It starts with 139. Get this and either call Sears or visit their store.
Jan 22, 2010 | Sears Craftsman LiftMaster Chamberlain...
Kitchen aid dishwasher not cleaning dishes well. especially the top rack. practically taken the whole thing apart can't find any clogs.
sounds like you have a broken chopper. have you checked the chopper how far have you taken it apart? if the unit is put back together point all wash arms in the same direction turn the dishwasher on after it has started washing give it about 2-3 minutes open the door and see what wash arm is not moveing. if the upper wash arm is not moveing you need to check the chopper.
Oct 18, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
BAD POWER WINDOW MOTOR
open the door pull the wiring loom back you may find a broken wire in there
May 29, 2009 | 1997 Chevrolet Cavalier
Hotpoint WD63
Sometimes the door lock doesnt engage properly! This could be the cause, give door a good slam shut. Hope this is of help.
Jun 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Samsung SF560 error message door open & jam, no toner.
I have put a new toner in and it says "[jam 1] or no cartridge" please help this is an office fax and desperately needs to be working.
Many thanks,
Adrian.
Apr 15, 2008 | Samsung SF-560 Plain Paper Laser Fax
LG WD-3243RHD Front Load Washer / Dryer Logo
74 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
