Question about Xerox Phaser 8200DP Thermal Printer
Xerox 8200DP connection problems
Hi, I think lightning hit my printer. I can no longer find the printer with either the usb connection or the ethernet connection. When the lightning hit it was connected to an single computer via usb. since I have tried both other ways with no luck. I don't know if the same board has both connections on it or 2 different boards.
Thanks for any help.
  • Xerox Master
  • 2,794 Answers
Is there power going to the printer?
Posted on Jun 10, 2008
Hi i ned to reset the maintenance for phaser8200dp color printer
Without expensive equipment to reset the chip I don't know of anyway to do this. If it is "expired" by date you can try going into the printer setup and back dating the year to "fool" the printer. I understand many people have had success doing this.
Sep 28, 2010 | Xerox Phaser 8200DP Thermal Printer
Model 7760 boots up to main menu but says it is warming up. Is this a problem with engine controller board ? Fuser is hot.
The Xerox Phaser must be connected to thenetwork via the ethernet cable or via the USB to a PC before you start it up.
If the printer can't "see" the network or PC via the Ethernet or USBconnections when you switch it on, the menu will display "warming up"continuously and when you try to access the menu, it will "freeze".When this happens, switch the printer off and make sure the Ethernet or USBconnections are connected properly before switching it back on.
Jun 29, 2010 | Xerox Phaser 7750DN Laser Printer
I have a xerox phase 8200dp. it was unplugged by
Check on the back of unit, there are blinking lights. Check the light next to the PS label and see if it blinks.
If not ....then you've got a bad Power Supply 650-4024-01
That's the most likely situation
Whit
Item, Inc
Nov 19, 2009 | Xerox Phaser 8200DP Thermal Printer
Using Phaser 8200 with Windows XP SP3 - when selecting CUSTOM paper size - Windows Explorer crashes
This happens most frequently with a bad driver install. You should go to Xerox.com and download the latest version of the device driver. Then reinstall the approrpaite driver and check to see how things go.
Oct 23, 2009 | Xerox Phaser 8200DP Thermal Printer
Usb hook up to computer
Hi dpelcowitz: You have to remove the rear right panel located on the right rear of the machine. When you remove the panel you will see the following. 3. Power cord connection 4. Power switch 5. Parallel port connection (8400 series only) 6. USB connection 7. Configuration card 8. Ethernet 10/100 Base-T connection. Hope this helps
Jun 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Powering Up My Xerox Phaser 8200DP
I assume no codes are coming up after leaving it on for a long time.
Most likely problem is the electronics module.
With the price of it you could buy 2 new dry ink phaser printers.
But what you are describing sounds like an electronics module issue.
May 27, 2009 | Xerox Phaser 8200DP Thermal Printer
Reset counter on Xerox Phaser 8200
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Oct 05, 2008 | Xerox Phaser 8200DP Thermal Printer
Xerox DocuPrint P8ex
In order for me to deal with this query for you i need get some informations:
- what operation system does you computer have?
- Are you gonna connect via parallel, USB, or External Ethernet Adapter
Fran10
Apr 10, 2008 | Xerox DocuPrint P1202 Laser Printer
Rg54g3 router problem
Lightning seems to have zapped the Ethernet port on the Modem side, the WAN port, this is quite common with telephone and cable line surges.
Consider your router smoked.
Apr 07, 2008 | MSI Wireless-G RG54G3 Router
Print server won't speak to printer
If I am correct, you are connecting the print server to the Xerox with a parallel cable.  If so, you are printing two different ways when you connect with an ethernet cable.  When you connect the printer with an ethernet cable you are probably printing TCP\IP to the IP Address of the NIC Card (in the printer).  When you connect with a print server, the print servers IP Address becomes the one you would use as the port for the printer object in Windows Printers & Faxes.
Oct 12, 2007 | Computers & Internet
Xerox Phaser 8200DP Thermal Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
