Question about Samsung TXF2899 28" TV
TV picture fades, then shuts off
Samsung TXF2899c CRT TV. The set has a beautiful picture (rich color, sharp ...). BUT after the TV has been on for 30 seconds or so, the picture fades and the left side crumbles and then the picture disappears and finally the TV shuts off. If I shut it off for 10 seconds or so, before it shuts itself off, the picture comes back and plays beautifully for the rest of the day.
The TV was doing the same thing a few months ago (except that the fading happened at random times), until the picture totally died (wouldn't come on at all). The service man changed the flyback transformer and the picture came back, but when I took it home, I found the modified problem I described above, where the TV fades/shuts off after 30 seconds ... etc.
Can someone please offer some clues as to what may be causing the problem.
Thanks,
Joel
  • Joeld49 Jun 10, 2008
    Jerry G.
    Thank you for your quick response. The TV is about 6 years old and cost about $1100. I would feel better if Samsung factory service could repair it, but apparantly they don't have a facility like that here in Montreal. Instead they have recommende service centres.
    I've used one of the centres they recommend, a long time ago, for an NEC VCR - they charged for the inspection, said it would cost $$$ to fix checking the unit - took it somewhere else and they fixed it in 2 seconds for free. So I'm a bit skeptical about these recommended service centres.
    Genius:
  • Samsung Master
  • 1,673 Answers
There are some components in the scan amplifiers, and or the power supply area that have become unstable. This can happen with age and use. It is impossible to make an accurate assessment without actually troubleshooting the set.
You need an experienced TV service tech that is strong on troubleshooting, has the service manuals, and has the proper set-up to work on your set. I would recommend the factory service rather than an independent service tech unless you know for sure that the independent service tech can handle this type of repair.
Considering the age of the model of set that you have, I would be looking at replacing it rather than fixing it. Because of the age of the set the reliability will be decreased.
Jerry G.
Posted on Jun 10, 2008
Samsung tv calibration
You're asking about the picture settings to this TV; I assume, and posts this solution. Just set it to user mode; in terms of picture; set the Color to minimum (0); Contrast = 70 ~ 75%; Brightness to 30 ~ 40%. In this way, just set a picture in Black/White first. If you see that the contrast or brightness level should be adjusted to get a good B/W picture, do it according to your viewing taste. After set this, advance the color; and compare the skin tone of a news reader at the studio.
In most cases, this must be the perfect adjustment. If you wish to get more details to picture, advance the Sharpness control. Do not set it too more. Less than 30% will be sufficient. If the broadcasting system is NTSC, you have to adjust the Hue too.
Apr 18, 2014 | Televison & Video
Sharp 21sn5 tv some time green colour incres and picture fade
you must test a) color sync 2) osci color 3) demod color 4) video amp color
however go to http://pdfservicemanual.com and download.
God bless you
Sep 25, 2012 | Televison & Video
My Samsung TXS3082WH 30 inc wide screen TV seems to be losing color and going in and out and i notice when you watch cartoons its fine but when it goes to actual shows or channels with normal footage it...
There have been a lot of problems with the Samsung sets, one dealer I know had so many complaints about the ones he sold he stopped selling them and switch to another brand and he has been trouble free ever since. To answer your question they have problems with the screens, color texture, lines, fade out to name a few, from what you have described you have at least two or three issues, considering the history I would replace it.
Jan 07, 2011 | Samsung SlimFit TX-S3082WH 30" TV
My first gen samsung dlp tv makes noise from back and will not turn.when it happened it was going in and out of color
Tv have a colors wheel.Colors fade in and out or flashes black and white within the picture.The tv making humming or loud motor noises the colors wheel is dying and not spinning correctly in it motor anymore.The tv must have it colors wheel replace,will solved this problems.
Jan 01, 2011 | Samsung DLP HL-P5663W 56" TV
I have a Samsung rear projection tv, the picture is faded and the colors are not crisp or clean cannot watch it like this what do you think the problem is?
If this is a CRT-type rear-projection TV, the CRT coolant fluid is probably broken down. It's supposed to be clear, but after a long period of TV operation, it turns a yellow-brown color. If you unplug the TV and remove the back, you can look into the tops of the three picture tubes. They should be a clear red, green or blue color, with no yellow-brown tint.
CRT coolant can be changed, but you need to be very good at mechanical work to do it. Besides the safety considerations (picture tubes and other parts may carry a high voltage charge even when the set is unplugged), spilling broken-down coolant on electronics is usually disastrous, so you have to be very careful.
LCD panels used in projector applications may lose contrast if they are overheated (this can be caused by failure to keep the vents clean as recommended in the owner's manual).
You would have to provide your set's model number to get more specific information.
Oct 27, 2010 | Samsung Televison & Video
Colors Faded in my sony KV-HA21M83A 21''
Its magnetic effect on picture tube. Power Off TV for 20-30 minutes then turn it On, hope problem will be resolved. Please also check and remove any speaker or some thing have magnet near by TV.
If color spots are still there, picture tube need to degaussed / demagnetized.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No color for my Sharp LC-30HV4U . . . but the menu has beautiful color . . is my tv shot?
have you checked the TV's Settings ? chances are the colour settings could be changed and the colours could be turned right down ?
if not, goto the sharp website at http://www.sharp.co.uk/pcat/support or www.sharpusa.com/products/support/ depending which country you are from. and see if they can solve your issue !
Hope this Helps !?
Oct 27, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Tv shuts off
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Sep 22, 2007 | Mitsubishi VS-55707 TV
Tv has bright green color
you are having a problem in your video circuit and your tunner section if the green is smooth also have the deflection ic checked.but this set needs to be taken to a qualified tech repairs could cost about $1oo.00 good luck.
Nov 16, 2006 | Samsung TXK2554 25" TV
Televison & Video Logo
267 people viewed this question
Henry  Thomas
Henry Thomas
