Question about Frigidaire ATF6000ES Front Load Washer
LG Front Loading Washing Machine
Could you please tell me which side of the detergent drawer is to fill with water first? If I use bleach the clothes smell like bleach when the cycle is complete not like softener. Could the water fill lines be crossed at the time of production. The softener side is filling before the detergent. Thank you for your help!
  • Anonymous Mar 14, 2014
    when filling the machine to wash the water runs out in the floor and drawers
  • 868 Answers
Bleach goes in on a calculated time.Yes some one could have reversed lines.Actually the harness i believe.
Posted on Jun 10, 2008
We have a LG He washing machine. It is 3 years old and get light use. Recently after each use the clothes are covered with brown soft specks How can we deep clean out machine?
hi David.
  1. Fill the washer using the highest load size, hottest water setting, and longest wash.
  2. Open the lid and as the washer tub fills, add a quart of white vinegar (or bleach). ...
  3. Next, add a cup of baking soda. ...
  4. Meanwhile, remove any parts you can and soak them and clean nooks and crannies under the lid.
More items...
How To Clean a Washing Machine ' Apartment Therapy
https://www.apartmenttherapy.com/how-to-clean-a-top-loading-washing-machine-apart...
How do you clean a front loading washing machine
Pour the vinegar into a measuring cup and head over to your washing machine.
  1. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. ...
  2. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue.
how to deep clean washing machine Google Search
Dec 03, 2017 | LG Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Water is leaking out of the detergent drawer. It
    i would say the outlet from the bleach area is blocked clean out drawer unit
    Apr 12, 2010 | LG WM2277H Front Load Washer
    Bleach not dispensing
    Make sure it is actually bleach, and not water. Most models with a bleach dispenser in the drawer actually dispense the bleach by adding water to the cup and allowing the mixture to overflow into the machine- so that pure bleach doesn't land on your favorite shirt before there is any water in the machine.
    Jul 30, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Lg tromm front loading washing machine has
    Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
    BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
    Update me about your progress
    Jul 20, 2009 | Washing Machines
    Water remains in detergent drawer
    bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
    Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Water inlet not filling
    check it has drained completely after the last cycle.
    if that is ok, take top off and check continuity thro the inlet valve coils
    Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
    Mold Smell in front loading LG Tromm
    Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
    Aug 15, 2007 | LG WM0642H
    Frigidaire ATF6000ES Front Load Washer Logo
    70 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
