Question about Carrier 38CKC036 Air Conditioner
Air conditioning yes my ac is not cooling off my apartment, i have had the maintenance guy in here about 3 times already and he said it isn't going to get much cooler than 20 degrees less than the temp outside. i know he is not a certified HVAC mechanic and he just keeps giving me the same anwsers every time i talk to him. He said the ac unit is old and i am in the up stairs apartment so all the heat from the downstairs is coming into my apartment, but i think it is a bunch of bull that he is trying to fill my head with. but my unit outside is good on freon and everything, also my unit keeps running constantly. i have my thermo set on about 76 degrees but it never goes below 80 all day and it runs the hell out of my unit and electricity. another question should he even be working on my HVAC system seems how he is not certified in any kind of ASE with heat and air
    Champion:
  • 254 Answers
Here are a couple things to check first make sure that the filter inside is clean if not replace. 2nd the outside coil needs to be cleaned at least once a year to ensure effeciency. These two things will make a dramatic improvement in operating costs and capability of the unit.
Posted on Jun 10, 2008
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
I am in saudiarab i have crown victoria 97 model it is working good but i have problum in air condition system when i run my car its running good no problum but when i start my air condition it is heating...
The air conditioning condenser creates a lot of heat when the a/c is on. The cooling fan is supposed to run the whole time the a/c is on to keep it cool. If the fan isn't on, the radiator will absorb this heat and cause your car to over heat. You should also check your coolant level. So, it sounds to me like your cooling fan isn't working.
Sep 13, 2011 | 1997 Ford Crown Victoria
Air conditioner blowing hot air and car overheating when idle
Air conditioning is one area where the owner generally is not qualified or equipped to perform the necessary repairs. If you are overheating and the ac isn't cooling I would check the condenser (radiator in front of the engine radiator) and made sure it's not obstructed. Also make sure that the electric fan comes on when you engage the A/C. Beyond that there isn't much you really can do except have an professional run a diagnostics on the system.
Aug 12, 2011 | 1997 Lexus ES 300
Not cooling very good anymore. its cool but not that good! all the settings work. one thing i did notice is that ice builds up on the cooling coil from compressor! ( ge room ac model # ast05lcs1...5500...
Your intuition is right, the ice buildup is why it's not cooling so well now: the evaporator isn't getting the correct air flow and surface area for heat exchange. The 1st thing you might want to check is to make sure that it's draining properly. The 2nd thing you might want to do is to check that the room is over 100 sqft. If you'r only cooling a tiny bedroom, the AC's basically oversized: your cooling already cooled air, so it freezes. The actual reason that is freezes is because the condition is just right for the immediate area near the evaporator to be at the saturation point. Think of it in terms of weather: warm and humid air collides with cool air and it begins to rain. The temperature drops further, and the rain turns into snow. One thing you could try to make it not freeze-up is to adjust the temperature setting a few degrees or change the fan speed.
Aug 04, 2011 | GE ASQ05LK 5,050 BTU Room Air Conditioner...
I have a Kenmore Air Condition. Did it requires freeon?
Hello, yes all air Conditioners require freon to cool, is your ac not cooling properly
Jun 08, 2011 | Heating & Cooling
Air conditioner maintenance
Replace the cabin air filter, located behind glove box.
Jan 19, 2010 | 2005 Mazda MPV
FEDDER'S PORTABLE UNIT SAYS STOP. WONT RUN
Disconnect power to the unit and reconnect. If "stop" is still on the display you will probably need a qualified technician to trouble shoot. The best mode is the snowflake (cooling). The rain drop is dehumidification which can cause condesation on unit.
Aug 30, 2009 | Fedders A&B Chassis A1A07W2B Air...
A/c not blowing cold...
Basically for him even saying what he said, was not the right guy. Most house units with the Square footage you provided have 2-3 lbs of refrigerant yes , If he said you needed three pounds he is lying becuase you ac compressor would have burned out a long time ago and it would also short cycle too.Meaning outside unit would go on then off rapidly. In most systems a compressor has a safety where if your dangerously low it will cut off but before that you ll notice your ac blowing hot air.So that was not cool him telling you that . I'm not there to check but a real tec. would check inside and outside keep the gauges on and let you know . "even after if he did "(put 3LBS)" he should of waited about 15-20 Min's to see if it were blowing cooler.my suggestion is in the attic" You might have some infiltration of humid air coming in . Which means cut or holes in the ducts.I Hope that helped any more questions fill free to ask .
P.S. Get a real tec Who would explain better no mom and pop joints"
Kevin a Sheet Metal worker In Commercial Heating and Air Conditioning.
Jul 03, 2009 | Heating & Cooling
Help!! No cooling, just fan!!!
sounds like the unit is low on charge.you will need a pro to check it
Aug 04, 2008 | Heating & Cooling
Carrier 38CKC036 Air Conditioner Logo
94 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
