Question about JVC TH-M505 System
JVC TH-M505 changer displays NO DISC
The disc changer displays NO DISC on screen and on the front panel regardless which disk drawer is used. System was working fine yesterday.
There are two rails in the dvd player. I have found that cleaning the rails & applying new grease to them usually solves the problem. a spray with silcone will do. do not get any on the laser. best done by a pro & not many know of this little trick.
Miyagi2
Posted on Jun 19, 2008
Jvc th-m505 disc changer will not open
There are 4 possible items that could be at fault.
LV41431-002A LOADING BELT VKS5557-001 LOADING GEAR LV21406-003A LOADING RACK
or it could be the main drive motor which I'm unsure of the Part No. for.
If you take the cover off and check that the motor is rotating and follow the belt, gear and rack from their to see which is slipping or not moving
Please leave feedback.
Cheers
Andy
Apr 25, 2011 | JVC TH-M505 System
Disc got stuck in dvd, got it out now dvd will read, do not hear dvd running then system says no disk. I tried laser cleaner disc and it played musaic then tried to foward it to trac 5 and it stopped and...
i think you need to clean the lens better try doing it by hand with alcohol you may have also dis aligned the lazer if so it needs to go to a pro
Apr 20, 2010 | JVC TH-M505 System
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Jun 17, 2009 | JVC TH-M303 System
JVC TH-M505 "No Disc" Readout
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
Hope this may help;
Regards,
VOTIT
Jun 08, 2009 | JVC TH-M505 System
Jvc dvd TH-C6 says locked and dvd wont eject
While the system is off
Press and hold the stop button and disc one open tray button at same time
It will say unlocked and then power up and you are good to go
Hope this helps i just unlocked mine got info from jvc user manual on website this link is the pdf
http://resources.jvc.com/Resources/00/00/95/LVT1147-001C.pdf
Jan 15, 2009 | JVC TH-M505 System
On my JVC TH-60 disk drawer will not open?
hello the problem you have is that the tray is not in time so the security switch dont let to open this try to get ifo how put on time or align the mark on main spindle against the small one hope you undrstood saludos
Jan 08, 2009 | JVC XL-F154BK 5-Disc CD Changer
Jvc th m505
instruction book says: on the center unit ONLY WHILE UNIT IS OFF there is a button with a square under it (on top of unit) press & hold also press & hold disc 1 eject button (arrow pointing up). The system turns on & "UNLOCK" appears on the display window.
May 27, 2008 | JVC TH-M505 System
JVC TH-M505 System Logo
60 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
