Question about Brother IntelliFAX 1250M Fax
Fax printing problem
My fax has started printing (or I should say not printing) on the right hand side of the page
I just tried the cleaning process and that doesn't solve the problem
I don't want to waste a cartige if that isn't the issue
advise please
  • 2 more comments
  • citygirl3 Jun 10, 2008
    this fax doesn't have a drum or fuser
    it takes ribbon cartiages
  • Caltex Jun 11, 2008
    my printer/ fax only prints on half of the paper what can I do?
  • Anonymous Aug 28, 2008
    Same problem. Only prints on one side. Cleaning per user manual did not help.
  • abbub Feb 27, 2009
    I have the same problem on my 1450mc and found a crack in the blue hold down. where might I acquier a new blue piece
The blue release lever that holds the ribbon cartride may be cracked or broken. The crack may be so fine, that it's not easy to see, so look carefully. Even the slightest crack will cause the ribbon cartridge to fit loosely enough so that the roller is not touching the paper. Whatever side is not printing, that's the lever that you should look at. That's what happened to mine. I was ready to buy a new machine, until I found that solution. To test it, I tried to copy something while pushing down on that side of the ribbon cartridge, and it printed fine--the whole page. I looked more closely at the lever, and found the crack.
Posted on Oct 27, 2008
    Problem Solver:
  • 5 Answers
U might want to check/ inspect the drum or fuser.
Posted on Jun 10, 2008
Epson Aculaser C1100 Just replaced Black Cartridge still printing with wide black line on right hand side of page
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Mar 30, 2011 | Epson Aculaser C1100 Printer
I have the hp 2640 half the right side of the page good but the left side is fain you can hardly see fade out form right to left side of the page
Most likely your print heads need to be cleaned. To do this go to start, devices and printers, right click on your printer and choose printing preferences, click on the color tab and at the bottom there will be an option that says printer services, click on this and click on clean cartridge. This should be all that you need to do! ;)
Oct 10, 2010 | HP LaserJet 2840 Printer
Ink not showing when printing
You may need to perform a head clean especially if the printer hasn't been used for a while.
The following is for XP but Vista and Win7 should be similar.
Click start/printers and faxes, right click on your printer ans select Printing Preferences from the drop down box.
Select the Maintainance tab click on head clean and follow that up with a nozzle check test page.
You may have to perform several head clean processes, once you get a clear nozzle check test page printed you should be good to go.
TIP use only one page for the nozzle checks as each check uses a page, Just reload the paper again until satisfied.
Jun 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Replaced ink cartridges but printer does not print
u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer next use this printer as a default one will give u an option to print a test page on "no" and hit next try to print and check
Nov 12, 2009 | HP OfficeJet 7110 All-In-One Thermal...
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
Right side of printed page is faded
pull out your drum unit and look inside machine above where the drum would be. you should see a black assembly that runs left to right with a "****" glass. may need a flashlight. clean that glass off with a clean rag. sometimes toner "scatter" will get on glass and cause this.
let us know,
Mar 26, 2009 | Brother IntelliFAX 4100 Laser Fax
Not printing whole page
Could be as simply as the right print margin in the application you are using. Try printing a test page by right-clicking on the printer in Printers and Faxes in Control Panel and select Properties. If the test page prints ok then check the margins in the application you are using - usually File>Page Setup. The right margin could be set to 5.0 in instead of 0.5 in.
Dec 15, 2008 | Lexmark X2600 InkJet Printer
Only top quarter of page is printed
How can a get the # recalled of a document was fax to.
Sep 02, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Ink bleed dark line down edge of page when printing with black ink
click Start and then Printers And Faxes.
Right-click your printer and then Printing Preferences.
Click the Maintenance tab to view what your printer can do from a software perspective.
Click "CLean Print Cartridge" to start it and let the cleaning process run its course.
You may have to do this a number of times to get the print head clean.
May 07, 2008 | Office Equipment & Supplies
Epson Rx420
Click Start - Printers and faxes
Right click on the printer icon and select properties.
Click on Advanced tab. Enable the option print directly to printer.
Click apply n OK.
Check for the result.
Dec 22, 2007 | Epson Stylus 1400 InkJet Photo Printer
166 people viewed this question
James Cagle
James Cagle
Jim Keysor
