Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Frigidaire side by side model #FRS6R5ESBC
I am replacing the fan blade on the motor next to the condensor. I am looking for information on which way the fan should spin. Currently it looks like its spinning counterclockwise, but I'm getting conflicting information whether this is correct or not. This is pulling air from the coils under the freezer out towards the compressor. Is this correct?
  • 828 Answers
Fan rotation is determined by the motor direction of rotation. Cool air should pass over the compressor then over the condenser. Look from the motor end for the direction of rotation. Drive to driven. Motor is the drive and fan blade is the driven.
Posted on Jun 10, 2008
Air is cold. Compressor outside works. The condensor will run for a little while, then shut off while compressor is still running.
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. purchase a new capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor.bobicehouse_96.jpg
Sep 14, 2011 | Frigidaire FAS155K1 Air Conditioner
Fan moves slowly ,compressor still hot even with a portable fan blowing on condensor ,but temps are back to normal. What would cause the fan to blow slowly and there is no obsructions
Ralph78yanks,
Your condenser fan (fan motor by compressor) is a variable speed and controlled by a computer board and compressor speed. If the fan motor slows down and the compressor is running in high, the unit can over heat and cause temperature issues in refrigerator sections. GE has a program which can see actual fan RPMs of motor. As I research this incomplete model number (7 possible different models) I see they all use the same fan motor Part# WR60X10209, this is a DC motor. Make sure you fan has not melted also. The heat from the compressor can melt the should or blade when this motor fails. I hope this information helps you..
Jul 11, 2011 | GE Profile PSW26P Stainless Steel Side by...
I have RUUD and just replaced the condensor fan motor with a 5 wire Protech....the old fan was wired with black connected to contactor, orange to one side of cap and brown to the other side of the...
look on the side of the motor it will have a wiring diagram your fan supplies voltage to the capacitor its self so two of your wires go to the capacitor not just one. good luck
Aug 11, 2010 | Heating & Cooling
Blade falling off condensor fan motor in Maytag refrigerator
When you replacd the motor if you used the factory stamped sheetmetal nut, you will have this situation, rplace the factory sheetmetal nut with a 1/4-20 standard nut and loctite on the threads and this will solve your problem.
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
The divider is overhot
Greetings,
I can tell you this..its most likely the condensor fan motor has stopped turning. it could have something stuck between the blades so remove back cover and find your fan motor..It will have a 5" fan blade on it. this is where you'll look for something between the blades. If nothing there. Be careful and spin the fan blade to see if it will start..If it does..It will most likely fail and you'll need a new motor. If you have a portable window fan or something like it...Have the fan blowing towards the compressor and leave it behind the refrigerator to keep air blowing and this will make your refrigerator freeze and cool...until you get a motor
Bruce
Oct 03, 2009 | Samsung RS2630SH Side by Side Refrigerator
I have a frigidaire refrigerator model #FRS6R5ESBC that stopped cooling. I replaced start relay on compressor and discovered that defrost control was burnt out replaced it also. now in less than 3 days...
Had one a couple years ago did the same thing. Found the compressor was going bad and was pulling too many amps thru the control. Ended up buying a new frig.
Apr 08, 2009 | Frigidaire FRS3R5EMB Side by Side...
Radiator/Condensor Fan. Which is Which?
The condensor fan is on the left (passenger side) should have 4 blades.
Jan 23, 2009 | 1995 Honda Accord
Samsung Frig
I had the same problem with my 2630. Unplugged the power cord and pulled the small panel off on the rear of the unit. The fan was working. I noticed a lot of dust built up on the condensor- the cooling fins were full of it. I took my small shop vac and cleaned off all that I could on the the surface of the condensor. Thought I'd try blowing it out in case I missed any in the inner part of the condensor. Reversed the hose on the shop vac so it would blow air and turned it on. Dust blew everywhere! Just vacuuming it out wasn't enough. No more problems with the heat- that seems to have cleaned it out so that the fan can now pull air across the condensor to properly cool it down. Hope this helps.
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Hot to the touch
Kathy, you probably have a condensor fan that failed. Remove the lower back panel behind the refrigerator. You will see the condensor, condensor fan and compressor. The condensor fan should be running any time the compressor is running. You might have something stopping the fan blades or the motor might be going bad itself. What you are describing is a classic example of a failed condensor fan motor. Catriver.
Apr 19, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Electrolux side by side fridge feezer model number:enl62981ks3
The condensor fan motor has failed. For now remove the back panel of the refrig and make sure that the blade hasnt fallen off the motor. If the motor is bad put  a fan back there so the compressor wont fail next.
Oct 15, 2007 | Refrigerators
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
143 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
