Question about Coby CS-P14 Computer Speakers
One speaker one of the speakers doesn't work.
  • 31 Answers
Make sure the all of the wires are connected properly and the jacks are connected to it's appropriate color in your soundcard
Posted on Jun 10, 2008
Rear right speaker doesn't work, no matter what we tried. We switched the speaker and cables with one of the others, but just that position (surround right) doesn't work.
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Sep 09, 2011 | Spherex Xbox 5.1 Surround Sound System...
I have a Technics SU-G70 Amplifier with a problem. Overall, it works fine except for a speaker issue. When turned on, the Left speaker output on the monitor is lit up from 0 to 120. Just below, the...
Sir the problem of your unit is the power IC the other channel of this IC is already faulty. unplug the unit to the main AC outlet then remove the cover of your unit you will see a large aluminum plate the power IC is attach to that heat sink in order to fix this you should replace the IC. Or can you give me the part number of the IC so I can determine the pin configuration. Good day and best regards.
Sep 15, 2011 | Technics Audio Players & Recorders
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
When i power it on it shuts off i got a kenwood kdc-mp825
Disconnect all of your speaker leads at the head unit, make sure none are touching, then power it back on. If it still cuts out, check your ground, if it doesn't, re-connect speakers one by one and test power again. It will either cut out when you get to a speaker or wire that's shorted, or work just fine. it's protecting itself from damage by cutting off when speakers are either bad or have shorted wiring. Most common shorted wiring happens on door speakers at the hinge. If it continues to cut off without speakers connected and you have a good ground, the unit needs service. If it still plays and you find the speaker or wire that's causing the problem, disconnect the wire at the speaker and test again, if it works, replace the speaker, if it doesn't, replace the wire. Hope this helps
Jul 07, 2011 | Kenwood Sirius KDC-MP825 CD Player
The right speaker doesn't work
Make sure all the cables are connected properly.
Treble must be at mid-setting.
Jun 26, 2011 | Altec Lansing ACS 495 Computer Speakers
I have a set of 5 mirage nanosat speakers. Two of them have no sound. The other 3 are fine. Moved from Condo to home. As far as I know they were working in the condo. Any Ideas?
First thing to do is diagnose where problem lies - speakers or receiver or maybe wires. Take a working speaker and hook it up to the same wire that a non-working speaker is currently connected to. If the speaker now works, the problem is in the speaker, if it doesn;t work the problem is either the wire itself or the receiver. If possibly the receiver, check speaker set up menu in the receiver to see that all the channels are turned on. Have you talked to the dealer you bought it from for help? I'd start there after diagnosing problem as described above.
Jan 19, 2011 | Mirage NANOSAT Speaker
My phone nokia 5130, it doesn't work at this time. But on the following days i can use with loudspeaker only now it doesn;t work
hi :) u mean before u can use with loudspeaker,mean the speaker hearing people talking cant work ?? if now both speaker cant work,mean both speaker was apoil.pls send to mobile shop exchange new speaker.
Jul 06, 2010 | Nokia 5130 Cellular Phone
Coby CS-P14 Computer Speakers Logo
48 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
