Question about Kitchen Ranges
Burners will not respond correctly to thermostat settings. (ie setting on low but burner will be red hot and burner setting on hot but will be low)
  • tfitzhugh Jun 10, 2008
    Thanks Sir! I'll try that switch.
  • 413 Answers
The corresponding switch that controls the burner should be replaced.
Posted on Jun 10, 2008
Oven gets warm but not hot?
This could be a thermostat issue or a burner issue. Most ovens have a top and bottom burner, if one of them is not working, the oven may not reach or stay at the right temperature. You should be able to get a replacement at home stores that sell appliances or order one online. They are fairly easy to replace. You may have to remove a couple of screws but otherwise they pop out and pop in. You can test the burners by turning the oven on bake and a few minutes later open the oven to see if the bottom burner is red, if not it may be burnt out. You can set the oven to broil and after a few minutes, look at the top burner, if it's not red it's likely burnt out. If both burners seem to be working, it is likely a thermostat issue. I haven't replaced one of them before, but you should be able to find instructions on youtube to determine if it is something you are comfortable replacing on your on.
Aug 11, 2017 | Ovens
Gas valve wont open in my oven
call your local repairman .
Nov 15, 2016 | Ovens
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
I have a Beaumark Electric range about 8 years old, The right front burner comes on high as soon as it is turned on, even if I turn it to low it remains on very, very high and burns everything. Why
The burner is not controlled and so it is possible that there is no control on the heating coils.The thermostat settings must be checked as this can be an area where the coils are not controlled for the heat set but goes to the highest level.You will need to remove the unit to check the control action of the controller, check the thermostat and sensor.
Nov 22, 2011 | Kitchen Ranges
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Oven won't ignite but broiler does
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Aug 11, 2009 | Ovens
Stove burner gets red hot
Since you do not have a thermostat control on your burners, I would suspect you may have an infinite switch (burner control), that controls that particular burner, possibly starting to go bad. The thermostat control is located on the infinite switch itself and may be cycling on and off improperly. Its hard to tell with intermittent problems, however. If in doubt, you can do a comparison between a working 8" inch burner and the one you are having problems with.
Another thing to consider with these coil type plug in burners, the receptacles under the cook top that they plug into can gradually become loose over time and cause the burners to arc. This may also cause excess current flow through the burner and will eventually cause burner coil damage and/or receptacle failure. I would troubleshoot this by, first, by unplugging the appliance and inspecting all the burner receptacles. If any show signs of burning or melting, replace them. You will need to lift the cook top to access them. Locate the screws under the bottom front edge of the cook top (open the oven door to see them) and remove them. With the screws removed, the cook top will lift up. Prop in place using the hinge supports.
NOTE: Remove the burner coils and bowls before lifting the cook top.
Replacements parts (including burner receptacles) can be purchased at pcappliancerepair.com, appliancepartspro.com, searspartsdirect.com, or repairclinic.com.
If you have any questions, please let me know. I hope this helps you.
Aug 02, 2009 | Kitchen Ranges
Oven won't light, even with ignitor getting red
Bake igniter
Other causes
May 23, 2009 | Magic Chef 9122 Gas Single Oven
Dean gas deep fryer burner on high will not respond to temp set
The thermostat is likely welded shut. You'll have to change it out.
Feb 25, 2009 | Dean SR14E Deep Fryer
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Kitchen Ranges Logo
158 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
